[Geomoose-users] fitting to reference map
Len Kne lkne at houstoneng.com
Tue Sep 7 09:50:16 EDT 2010
A couple things to try:
1. Set the GeoMOOSE configuration option "fractional_zoom" to true, this will allow the map (and reference map) to draw at scales other than those values defined in the Mapbook.
2. You might need to add a higher value to the "scales" configuration option so the map can zoom out further.
3.  Try increasing the "max_extent" option.  You may need to have a max_extent that is larger than the initial_extent to get the reference map to work correctly.
Len
-----Original Message-----
Sent: Tuesday, September 07, 2010 3:32 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] fitting to reference map
Dear all,
it's the first time I'm using geomoose and I love it. Thank you very much it's a useful product.
I have built a project with a reference map. How is it possible to make fit the layers I have in it to the dimension of my reference map (especially when I open for the first time the project)?
This is a screenshot with the view I have when I open my project:
http://bit.ly/a86TMR
I'm using GeoMOOSE 2.2 for MS4W.
Thank you,
a
View this message in context: http://geomoose-users.964460.n3.nabble.com/fitting-to-reference-map-tp1431244p1431244.html
Sent from the Geomoose-users mailing list archive at Nabble.com.
This SF.net Dev2Dev email is sponsored by:
Show off your parallel programming skills.
Enter the Intel(R) Threading Challenge 2010.
http://p.sf.net/sfu/intel-thread-sfd
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
