[Geomoose-users] NFHL WMS from mapfile
Dan Little
danlittle at yahoo.com
Wed Sep 15 09:46:07 EDT 2010
Are you getting a Pink Screen of Death in GeoMOOSE? If the image is blank then I
would be that MapServer is trying to request an image larger than the restricted
size (1024x1024).
>From: "Miller, Elizabeth (DOT)" <Elizabeth.Miller at state.mn.us>
>To: Dan Little <danlittle at yahoo.com>; "geomoose-users at lists.sourceforge.net"
><geomoose-users at lists.sourceforge.net>
>Sent: Wed, September 15, 2010 8:33:21 AM
>Subject: RE: [Geomoose-users] NFHL WMS from mapfile
>Here is the map-source from the mapbook:
><map-source name="fema" type="mapserver" tiled="false" reference="false">
><file>/ms4w/apps/metrogis/maps/mapfiles_metro/WMS/fema_wms.map</file>
><layer name="Flood Data Availability"/>
></map-source>
>And in the catalog portion of the mapbook:
>http://msc.fema.gov
>I should also add that there are scale restrictions on the various layers in the
>service, but I have tried various layers and can’t get any of them to work.
>“Flood Data Availability” may not have been the best example to use here because
>it does not display at large scales (larger than 1:300,000).
>Also, the service is not tiled and the maximum image size is 1024 x 1024 pixels.
>ArcMap is able to bring it in and it displays correctly.
>I can get the service to display in Geomoose if I reference it directly from the
>mapbook but I would like to use a mapfile and bring it in that way. If I pull it
>in directly in the mapbook this works:
> <map-source name="fema" type="wms" tiled="false"
>reference="false" projection="EPSG:4326">
>http://hazards.fema.gov/wmsconnector/wmsconnector/Servlet/NFHL?
> <layer
>name="Flood_Hazard_Zones_General"/>
> <layer name="Q3 Flood Hazards
>(red)"/>
> <layer name="Floodways"/>
> <param name="format"
>value="image/jpeg"/>
> <param name="TRANSPARENT"
>value="TRUE"/>
> <param name="styles"
>value=""/>
> </map-source>
>From:Dan Little [mailto:danlittle at yahoo.com]
>Sent: Tuesday, September 14, 2010 3:19 PM
>To: Miller, Elizabeth (DOT); geomoose-users at lists.sourceforge.net
>Subject: Re: [Geomoose-users] NFHL WMS from mapfile
>Can you attach the Mapbook? or Copy and paste the mapbook entry that pertains to
>the WMS?
>>From:"Miller, Elizabeth (DOT)" <Elizabeth.Miller at state.mn.us>
>>To: "geomoose-users at lists.sourceforge.net"
>>Sent: Tue, September 14, 2010 11:32:59 AM
>>Subject: [Geomoose-users] NFHL WMS from mapfile
>>I have not been able to bring in the FEMA NFHL Flood Mapping WMS into my
>>Geomoose map via a mapfile. What am I missing? Can anyone help??? Here is my
>>mapfile. I have tried both “Flood Data Availability” and “HDM:Q3_COUNTYMAP” as
>>the wms_name, and have tried calling both from the map-source in the mapbook
>>file. Maybe there is a problem with the extent?
>>Thank you for any help.
>>Liesa Miller
>>MnDOT
>>Saint Paul, Minnesota
>>MAP
>> NAME 'fema_wms'
>> SIZE 800 650
>> STATUS ON
>> EXTENT 189783.560000 4816309.330000 761653.524114 5472346.500000
>> UNITS METERS
>> IMAGETYPE PNG
>> TRANSPARENT TRUE
>> WEB
>> INCLUDE "../../temp_directory.map"
>> END
>> PROJECTION
>> 'init=epsg:26915'
>> END
>> LAYER
>> NAME Flood Data Availability
>> TYPE RASTER
>> STATUS DEFAULT
>> OFFSITE 0 0 0
>> CONNECTIONTYPE WMS
>> CONNECTION
>>"http://hazards.fema.gov/wmsconnector/wmsconnector/Servlet/NFHL?"
>> METADATA
>> "wms_title" "Flood Data Availability"
>> "wms_srs" "EPSG:4326"
>> "wms_name" "HDM:Q3_COUNTYMAP"
>> "wms_server_version" "1.1.1"
>> "wms_format" "image/png"
>> "wms_styles" ""
>> "wms_exceptions" "application/vnd.ogc.se_inimage"
>> END
>> PROJECTION
>> "init=epsg:4326"
>> END
>> END #layer
>>END #Map
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100915/ebf54c48/attachment.html
More information about the Geomoose-users
