[Geomoose-users] NFHL WMS from mapfile
Eli Adam
EAdam at co.lincoln.or.us
Wed Sep 22 10:38:02 EDT 2010
Sean,
The wms can work like that. It can also give pink tiles. If you use a larger monitor or set your monitor resolution to the highest setting such that the wms requests tiles larger than 1024x1024, you will get pink tiles.
When I attempt to avoid the pink tiles on high resolution/large screens by changing tiled="false" to tiled="true" then I get substantial shifts that are proportional to the zoom level.
Is there a better way to use this wms so that neither of these two issues are present?
Bests, Eli
3. NFHL WMS from mapfile (Sean Ziniker)
Message: 3
Date: Tue, 21 Sep 2010 13:47:34 -0700
From: "Sean Ziniker" <Sean.Ziniker at co.jefferson.or.us>
Subject: [Geomoose-users] NFHL WMS from mapfile
To: <geomoose-users at lists.sourceforge.net>
Message-ID:
<35242CE7ADE78B43810D2B9F1A012D8A01BA66B6 at exchange.jefferson.local>
Content-Type: text/plain; charset="us-ascii"
Eli,
I am able to successfully use the DRG WMS that you posted. I put it in
exactly as you wrote it and am not having pink screen issues at zoom
levels. Below is what I used for map-source and catalog:
<map-source name="DRG" type="wms" projection="EPSG:4326"
queryable="false" tiled="false">
<url>http://msrmaps.com/ogcmap.ashx?</url>
<layer name="DRG"
queryable="false" />
<param
name="TRANSPARENT" value="TRUE"/>
<param name="FORMAT"
value="image/png"/>
</map-source>
<layer title="USGS Topography" src="DRG/DRG" status="off" legend="false"
fade="true" unfade="true"/>
I am also using the google projection with fractional zoom set to false.
Don't know if that matters.
Thanks for the post,
Sean
Sean Ziniker
GIS Analyst
Jefferson County, Oregon
66 S.E. "D" Street, Suite B
Madras, OR 97741
541.325.5083 Office
541.325.5089 Fax
More information about the Geomoose-users
