[Geomoose-users] Access data outside "data" folder
    Sean Ziniker
    Sean.Ziniker at co.jefferson.or.us
    Wed Sep 22 12:23:49 EDT 2010
Here is what my mapfile looks like:
LAYER
                        NAME 'HalfMeter2009'
                        STATUS ON
                        TYPE RASTER
                        PROJECTION
                                    'init=EPSG:2913'
                        END
                        TILEINDEX './data/HalfMeter2009_Index'
                        TILEITEM 'LOCATION'
            END
The TILEINDEX references a shapefile that indexes the images and has an
attribute named LOCATION that has the path to the images.  I started to
go down the DBF catalog route but everything I found on Mapserver talked
about a shapfile index.
Here is what the LOCATION attribute looks like: E:/New
GIS/JeffCOGISDATA/Aerials/Jefferson/HalfMeter2009/44120-D7
I finally got it to work with these settings.  I found an error in my
attribute location path string that was hanging it up.
Thanks for all the help,
Sean
Sean Ziniker
GIS Analyst
Jefferson County, Oregon
66 S.E. "D" Street, Suite B
Madras, OR 97741
541.325.5083 Office
541.325.5089 Fax
Sent: Wednesday, September 22, 2010 6:52 AM
To: Sean Ziniker; geomoose-users at lists.sourceforge.net
Subject: RE: Access data outside "data" folder
Hi Sean
You could put in the full path to the data tag (removing the "." )
and/or add the SHAPEPATH tag to the map file.
Len
From: Sean Ziniker [mailto:Sean.Ziniker at co.jefferson.or.us]
Sent: Tuesday, September 21, 2010 3:18 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Access data outside "data" folder
I was just wondering if there is a way to access data outside the
'ms4w\apps\geomoose2\maps\data\' folder.  I have imagery that I would
like to access via a TILEINDEX but I can only get to work if the imagery
is within the geomoose data folder.  It would be nice to not have to
duplicate that many large files on my server.
Thanks,
Sean
Sean Ziniker
GIS Analyst
Madras, OR 97741
541.325.5083 Office
541.325.5089 Fax
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100922/4da968f7/attachment.html
More information about the Geomoose-users
