[Geomoose-users] GeoMoose and extjs
Dan Little
danlittle at yahoo.com
Mon Sep 27 12:42:47 EDT 2010
You're probably going to want to avoid using ExtJS if you can and stick with
Pure JQuery. I believe that's what Len is doing to get things to play nice.
>From: Dante Fuster <dante.fuster at gmail.com>
>To: Dan Little <danlittle at yahoo.com>
>Sent: Mon, September 27, 2010 11:40:48 AM
>Subject: Re: [Geomoose-users] GeoMoose and extjs
>Hi
>I need to show a window with the consulted information or processed and that
>works with the map (zoom, draw, etc), like the function windows in extjs,
>however when adding the sentences to the file map.html,
><link type="text/css" rel="stylesheet" href="skins/white/white.css"/>
> <!-- add extjs-->
> <link rel="stylesheet" type="text/css" href="ext/resources/css/ext-all.css"/>
> <script type="text/javascript"
>src="ext/adapter/jquery/ext-jquery-adapter.js"></script>
> <script type="text/javascript" src="ext/ext-all.js"></script>
>src="./proj4js/lib/proj4js-compressed.js"></script>
>src="./proj4js/lib/defs/EPSG32718.js"></script>
>the map stops to be shown, and is not draw in the map.
>greetings
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100927/60c82798/attachment.html
More information about the Geomoose-users
