[Geomoose-users] using Google layers as background
John Callahan
john.callahan at udel.edu
Fri Apr 15 15:25:48 EDT 2011
I'm creating a GeoMoose application that will use the various Google tile
layers as backgrounds. (I originally created a basic app in my local state
plane projection but then realized that the Google-like backgrounds are
critical.) I've downloaded the Web Mercator demo and am looking at
http://geomoose.org/howto/commercial_layers.html for guidance. As I go
through this, a few quick questions:
1) Should I use EPSG:3857, EPSG:3785 or EPSG:900913? Or does it matter as
long as Proj4 supports it and there's a corresponding file in
proj4js\lib\defs
2) In the mapbook file, should all the data sources (nearly all of WMS type)
have the same projection attribute, such as projection="EPSG:3857"?
3) Just to confirm, my raw data files do not need to be in the "web
mercator" projection, only the MAP Projection and Extent parameters in the
map files, correct?
- John
John Callahan, Research Scientist
Delaware Geological Survey
University of Delaware
URL: http://www.dgs.udel.edu
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110415/6faa9428/attachment.html
More information about the Geomoose-users
