[Geomoose-users] Geomoose 2.2 and ms4w-3.0.2
Dan Little danlittle at yahoo.com
Wed Apr 20 08:52:54 EDT 2011
Yep.  GeoMOOSE 2.2 does not work with MS4W 3.X, you'll need GeoMOOSE 2.4 (currently in RC1) to work with MS4W 3.X.
>________________________________
>From: aborruso <aborruso at gmail.com>
>To: geomoose-users at lists.sourceforge.net
>Sent: Wednesday, April 20, 2011 6:10 AM
>Subject: Re: [Geomoose-users] Geomoose 2.2 and ms4w-3.0.2
>Dear All,
>I have updated my ms4w to 3.0.2 and I have downloaded and installed Geomoose
>2.2 for ms4w.
>All seems ok, but when I use "Search Parcels" tool (and make a search by
>owner) I have a strange behavior:  Geomoose gives me in the map the right
>query result (polygons highlighted in yellow), but it does not give to me
>the list of owners in the Information tab on the right. In the the tab I
>have only "GeoMOOSE Item Query Results", and then a white box.
>Is there some compatibility problem between  Geomoose 2.2 and ms4w-3.0.2?
>Thank you very much,
>a
>View this message in context: http://geomoose-users.964460.n3.nabble.com/Geomoose-2-2-and-ms4w-3-0-2-tp2842352p2842352.html
>Sent from the Geomoose-users mailing list archive at Nabble.com.
>Benefiting from Server Virtualization: Beyond Initial Workload
>Consolidation -- Increasing the use of server virtualization is a top
>priority.Virtualization can reduce costs, simplify management, and improve
>application availability and disaster protection. Learn more about boosting
>the value of server virtualization. http://p.sf.net/sfu/vmware-sfdev2dev
>_______________________________________________
>Geomoose-users at lists.sourceforge.net
>https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110420/09c613b2/attachment.html
More information about the Geomoose-users mailing list
