[Geomoose-users] Problem getting WMS to display
Bistrais, Bob Bob.Bistrais at maine.gov
Thu Apr 21 11:27:02 EDT 2011
Perfect!  Thanks Dan!!
Sent: Thursday, April 21, 2011 11:25 AM
To: Bistrais, Bob; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Problem getting WMS to display
Try this...
            <map-source name="NAIP_2009" type="wms" tiled="false"
projection='EPSG:26919'>
<url>http://mapserver.maine.gov/wms/mapserv.exe</url>
                        <layer name="NAIP_2009" queryable="false"/>
                                    <param name="map"
value="c:/wms/orthos.map"/>
                        <param name="format" value="image/png"/>
                        <param name="TRANSPARENT" value="TRUE"/>
            </map-source>
	To: geomoose-users at lists.sourceforge.net
	Sent: Thursday, April 21, 2011 10:22 AM
	I'm trying to add a WMS layer to my GeoMoose application, but am
having trouble.  So far, the best I can do is get the layer to display
in the TOC, but it's a pink screen if you turn the layer on.  I'm not
sure what I'm doing wrong.  Here is what I have in my mapbook.xml file:
	In the map source section:
tiled="false" projection='EPSG:26919'>
<url>http://mapserver.maine.gov/wms/mapserv.exe?map=c:/wms/orthos.map?</
url>
queryable="false"/>
	            </map-source>
	And in the layer controls:
	                        <layer title="Aerial photos"
src="NAIP_2009/NAIP_2009" status="off" fade="true" unfade="true"
legend="false" />
	The URL to the WMS service is as follows:
http://mapserver.maine.gov/wms/mapserv.exe?map=c:/wms/orthos.map&SERVICE
=WMS&
	-it is a service which I know to work.  Also, I have a workable
projection file for EPSG:26919
	What am I missing here?
	Benefiting from Server Virtualization: Beyond Initial Workload
	Consolidation -- Increasing the use of server virtualization is
a top
	priority.Virtualization can reduce costs, simplify management,
and improve
	application availability and disaster protection. Learn more
about boosting
	the value of server virtualization.
http://p.sf.net/sfu/vmware-sfdev2dev
	Geomoose-users mailing list
	Geomoose-users at lists.sourceforge.net
	https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110421/1b7713d4/attachment.html
More information about the Geomoose-users mailing list
