[Geomoose-users] Re: Identify & popup issues
Efstathios Arapostathis
e.arapostathis at gmail.com
Sat Dec 3 12:16:01 EST 2011
Ok I'm trying the link you gave me to university's server and I'm getting
this error:
*Fatal error*: Call to undefined function ms_shapeObjFromWkt() in *
C:\ms4w\apps\museum_geomoose2\htdocs\php\popups.php* on line *32*
I'm also experiencing problems in loading my postgis layers. I'm geting
pink images and when I try to see the error
by executing the query (I found it under Mozilla's menu tools-->page info
--> multimedia) I'm not getting any error message. Only
a blank screen.
I can see my database though, by loading it in QGIS so it's not a
database's problem.
Server's software is: MS4W 2.2.6 with PHP 5.2.4 and postgresql 8.3.
I'm probably using geomoose2 or geomoose2.2 (I'm not sure about the
version cause this app was developed about 18 months ago and I don't know
how to check it)
Any ideas?
best regards,
Stathis
On Tue, Nov 29, 2011 at 8:35 PM, Dan Little <danlittle at yahoo.com> wrote:
> Something nasty is dying on your server:
> When this URL returns something, ANYTHING, things will be "working":
> http://www.hellas-gis.com/museum_geomoose2/htdocs/php/popups.php?layer=perioxesgmerc%2Fperioxesgmerc&shape=POINT(2406849.1463086%204745210.7152832)&_moosetime=1322591692504
> You'll need to check the server's error logs as to why the PHP script is
> dying.
> *From:* Efstathios Arapostathis <e.arapostathis at gmail.com>
> *To:* geomoose-users at lists.osgeo.org
> *Sent:* Sunday, November 27, 2011 1:43 PM
> *Subject:* [Geomoose-users] Re: Identify & popup issues
> I've corrected the temp folder path in settings.ini and now when trying to
> use identify I'm receiving a popup window with this message:
> "No valid response"
> Maybe you could check it by youself in this url:
> http://www.hellas-gis.com/museum_geomoose2/htdocs/#
> Thanks again,
> Stathis
> On Sun, Nov 27, 2011 at 8:47 PM, Efstathios Arapostathis <
> e.arapostathis at gmail.com> wrote:
> Hi,
> I've uploaded a geomoose app to a server, but I'm having troubles using
> identify and popup services.
> I'm receiving this message:
> "Fatal error: Call to a member function queryByShape() on a non-object in
> /var/www/vhosts/
> hellas-gis.com/httpdocs/museum_geomoose2/htdocs/php/identify.php on line
> 129"
> Any ideas on what is wrong?
> Thanks,
> Stathis
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111203/247dccef/attachment.html
More information about the Geomoose-users
