[Geomoose-users] Feature Editor: Polygon_update and Polygon_delete Errors
Atif Butt matifbutt at gmail.com
Wed Dec 7 01:03:37 EST 2011
Yes
this is my test_polygon.ini file settings
; Basic Connection Information
       host=localhost
       dbname=postgis
       username=postgres
       password=xxxxxxx
; Table Information
       tablename=test_polygons
       geometry_column=wkb_geometry
       primary_key_column=polygon_id
       primary_key_sequence=test_polygons_seq
       srid=26915
; Required Columns
; This is a comma separated list of columns required
; for creating or updating features in this layer
      required_for_create=wkb_geometry,title
      required_for_update=title
; GeoMOOSE Information
       layerpath=poly_editor/polygons
Regards
Atif
On Tue, Dec 6, 2011 at 11:24 PM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>  Do you have the primary_key_column defined in the ini file?
> Best Regards,
> Brent Fraser
> On 12/6/2011 7:24 PM, Atif Butt wrote:
> Hi
> Is there any other steps needs to do (except written inside the feature
> editor document) for "polygon_update and ploygon_delete". Because after
> doing these steps, when I use update polygon feature I am getting this
> message (1No Feature ID available for update.) and when I use
> delete_polygon tool, it says "No Feature ID specified to delete."
> I think something is missing.
> kindly check (http://99.243.192.221/geomoose2/geomoose.html) and give me
> your suggestions.
> Best Regards
> Atif
> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111207/c2db3b41/attachment.html
More information about the Geomoose-users mailing list
