[Geomoose-users] Re: Identify & popup issues
Efstathios Arapostathis
e.arapostathis at gmail.com
Sat Dec 10 08:22:29 EST 2011
Problem has been solved by installing mapserver's latest version.
Thanks for your help
regards,
Stathis
On Thu, Dec 8, 2011 at 8:49 PM, Jim Klassen <klassen.js at gmail.com> wrote:
> I don't know if this is related, but I doubt anyone has tested against
> MapServer 5.0.0 in a long time.
> On Dec 8, 2011, at 11:25, Brent Fraser <bfraser at geoanalytic.com> wrote:
> The important part is that is has "SUPPORTS=GEOS", so that's good (from
> Googling, this is the component that supplies the ms_shapeObjFromWkt
> function to mapserver).
> You've got a serious and uncommon mapserver configuration problem. To
> figure out why the function is not available, I'd recommend making a simple
> PHP script containing ms_shapeObjFromWkt and executing it from command
> line. Or use PHP's get_extension_funcs('MapScript') function to list the
> function names that are available in mapserver's MapScript:
> <?php
> if(!extension_loaded('MapScript')) {
> dl('php_mapscript.'.PHP_SHLIB_SUFFIX);
> echo implode('<br /> ', get_extension_funcs('MapScript') ), '<br />';
> Best Regards,
> Brent Fraser
> On 12/8/2011 9:47 AM, Efstathios Arapostathis wrote:
> Hi,
> The following message appears:
> *MapServer version 5.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
> SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE*
> On Wed, Dec 7, 2011 at 6:56 PM, Brent Fraser < <bfraser at geoanalytic.com>
>> Using a command line (in the directory containing mapserver executed by
>> your webserver) what does the command "mapserv -v" show?
>> Best Regards,
>> Brent Fraser
>> On 12/7/2011 9:38 AM, Efstathios Arapostathis wrote:
>> It's already uncommented..
>> Any ideas?
>> *Config.php:*
>> <?php
>> /*Copyright (c) 2009, Dan "Ducky" Little & <http://GeoMOOSE.org>
>> GeoMOOSE.org
>> Permission is hereby granted, free of charge, to any person obtaining a
>> copy
>> of this software and associated documentation files (the "Software"), to
>> deal
>> in the Software without restriction, including without limitation the
>> rights
>> to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
>> copies of the Software, and to permit persons to whom the Software is
>> furnished to do so, subject to the following conditions:
>> The above copyright notice and this permission notice shall be included in
>> all copies or substantial portions of the Software.
>> THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
>> IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
>> FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
>> THE
>> AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
>> LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
>> FROM,
>> OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
>> THE SOFTWARE.*/
>> # This is meant to allow specific environmental includes for
>> # GeoMOOSE 2 PHP Services. Substantive configuraiton options
>> # should be added to settings.ini
>> /* Check for the required libraries
>> * g2/curl are used for printing. If you're not using printing
>> * you can avoid using these modules.
>> * mapscript and dbase are used for most operations using them
>> * cannot be avoided
>> if(!extension_loaded('gd') && !extension_loaded('gd2')) {
>> dl('php_gd2.'.PHP_SHLIB_SUFFIX);
>> if(!extension_loaded('curl')) {
>> dl('php_curl.'.PHP_SHLIB_SUFFIX);
>> if(!extension_loaded('dbase')) {
>> dl('php_dbase.'.PHP_SHLIB_SUFFIX);
>> # Load the configration file
>> $CONFIGURATION = parse_ini_file('../../conf/settings.ini');
>> function getMapbook() {
>> global $CONFIGURATION;
>> $mapbook = new DOMDocument();
>> $mapbook->load('../../conf/'.$CONFIGURATION['mapbook']);
>> return $mapbook;
>> function getUsername() {
>> session_start();
>> return $_SESSION['username'];
>> # Select Functionality ONLY works for Mapserver Layers
>> function getMapfile($mb, $layerName) {
>> $services = $mb->getElementsByTagName('map-source');
>> $mapfiles = array();
>> for($i = 0; $i < $services->length; $i++) {
>> $service = $services->item($i);
>> $root = $service->getAttribute('name');
>> $layers = $service->getElementsByTagName('layer');
>> for($l = 0; $l < $layers->length; $l++) {
>> $layer = $layers->item($l);
>> $path = $root.'/'.$layer->getAttribute('name');
>> if($path == $layerName) {
>> return
>> $service->getElementsByTagName('file')->item(0)->nodeValue;
>> return null;
>> # get a source based on it's name
>> function getMapSource($mb, $layerName) {
>> if($services->item($i)->getAttribute('name') == $layerName) {
>> return $services->item($i);
>> return null;
>> On Mon, Dec 5, 2011 at 6:52 PM, Eli Adam < <eadam at co.lincoln.or.us>
>> eadam at co.lincoln.or.us> wrote:
>>> Since you are using PHP 5.2.4 I don't think that is an issue, but in
>>> later PHP versions, dl has been removed,
>>> <http://us2.php.net/manual/en/function.dl.php>
>>> Eli
>> Geomoose-users mailing list <Geomoose-users at lists.osgeo.org>Geomoose-users at lists.osgeo.org <http://lists.osgeo.org/mailman/listinfo/geomoose-users>http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111210/ed0201f4/attachment.html
More information about the Geomoose-users
