[Geomoose-users] Setting up first geomoose app
Brent Fraser bfraser at geoanalytic.com
Fri Jan 14 12:22:12 EST 2011
I agree with Bob; it's better to go with a standard.  But for the purposes
of resolving config problems, I like to use the mapserver protocol (it's
better supported/tested in GeoMoose).  Once things are working, switching
to WMS has excellent benefits.
And I think for future releases of GeoMoose we should concentrate on
WMS,WFS as the "standard" protocol for the demos etc.
Brent
> All,
> I've been following the thread (any keeping quiet in order to not confuse
> things) and would like to add in my 2cents on the WMS angle.  I (we've)
> been going the route of providing everything in a WMS that we publish as a
> standard, and it's paid off very well with regard to interoperability
> issues.
> We use WMS in AutoCAD, ESRI, QGIS, Google Earth to name a few.  Having the
> WMS allow much more flexibilty with regard to distribution of the data.
> While you don't need the data to be in a WMS form for GeoMoose, I would
> advise that you set up your services with WMS (and WFS) in mind to
> eventually be serverd.
> Ok, I'm done . . . .
> bobb
>>>> Carl Burn <burnsy at northcountrywoods.co.uk> wrote:
> Hi,
> I will get right on it, I have been asked if it can be done using wms -
> though I am not sure why, things sometimes take a while to filter down to
> my level ;-)
> The main aim is simply to get it working and showing maps which hopefully
> I can go ahead and resolve now, once again thanks for your help.
> Carl
> On Fri, Jan 14, 2011 at 4:30 PM, Brent Fraser <bfraser at geoanalytic.com>
> wrote:
> The map file should have:
> UNITS METERS
> EXTENT 41069.1 -1149.02 665378.01 1231178.57
> PROJECTION
> 'init=epsg:27700'
> END
> The mapbook.xml should have:
> <param name="max_extent">41069.1 -1149.02 665378.01 1231178.57</param>
> <param name="initial_extent">41069.1 -1149.02 665378.01 1231178.57</param>
> <param name="projection">EPSG:27700</param>
> and carefully follow the directions in
> http://www.geomoose.org/docs/projections.html
> and remove projection="EPSG:4326" from the <map-source> definition.
> Do you have a specific need to use WMS or can you just use the native
> mapserver protocol?
>> OK, thanks, have altered all refs to read epsg:27700
>> How do I enter the extent information as it seems to look nothing like
>> the
>> other entries I can find, sorry if this is a dumb question but as you
>> can
>> most likely tell this is not my normal area of work. The entries for
>> extent
>> that I can see in qgis are
>> When imported as a shp file:
>> In layer spatial reference system units : xMin,yMin 41069.1,-1149.02 :
>> xMax,yMax 665378.01,1231178.57
>> When imported as a wms layer
>> 41069.0999999999985448,-1149.0199999999999818 :
>> 665378.0000000000000000,1231180.0000000000000000
>> Carl
>> On Fri, Jan 14, 2011 at 3:38 PM, Brent Fraser
>> <bfraser at geoanalytic.com>wrote:
>>> Then I'd recommend changing all the projection references in your map
>>> file
>>> and mapbook to be:
>>> EPSG:27700
>>> since that matches the definition you gave for the data. See
>>> http://spatialreference.org/ref/epsg/27700/ for more info...
>>> > Hi, Brent,
>>> > I have no preferences as to the system, the files are delivered in
>>> tmerc
>>> > so
>>> > I guess I might as well use that as then I will not have to convert
>>> them
>>> > should new ones become available.
>>> > Carl
>>> > On Fri, Jan 14, 2011 at 3:21 PM, Brent Fraser
>>> >> Carl,
>>> >> You still haven't corrected the extents to match your projection.
>>> >> Until
>>> >> you do it won't work.
>>> >> Which coordinate system do you want to use for display? longlat or
>>> >> tmerc?
>>> >> Brent
>>> >> > Hi,
>>> >> > yep sorry my error, I have altered the units to DD but am not
>>> really
>>> >> any
>>> >> > further forward, I took a look at the data for the layers I need
>>> to
>>> >> add
>>> >> > and
>>> >> > I think I may need to either alter the projections section in the
>>> map
>>> >> file
>>> >> > or reproject the data.
>>> >> > When I check the properties of the file in qgis I get the
>>> following:
>>> >> > +proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000
>>> >> +y_0=-100000
>>> >> > +ellps=airy +datum=OSGB36 +units=m +no_defs
>>> >> > Luckily I only need to worry about three data files and they are
>>> all
>>> >> > identical in terms of the projection information I can see from
>>> the
>>> >> > properties dialogue boxes in qgis.
>>> >> > Does this sound reasonable?
>>> >> > Cheers
>>> >> > Carl
>>> >> > On Fri, Jan 14, 2011 at 1:36 PM, Johan Forsman
>>> <Johan.Forsman at la.gov>
>>> >> > wrote:
>>> >> >> The extent sections in both of your attached files are still in
>>> units
>>> >> >> incompatible with your chosen projection. Did you perhaps attach
>>> >> >> uncorrected
>>> >> >> versions?
>>> >> >> You indicate units of INCHES in the MAP file but WGS84 is defined
>>> by
>>> >> >> decimal degrees (DD). If you are in the UK you ought to be inside
>>> a
>>> >> box
>>> >> >> described by (-11 49 2 61), or something similar to that provided
>>> I
>>> >> have
>>> >> >> the
>>> >> >> bottom-left top-right sequence correct.
>>> >> >> /Johan.
>>> >> >> *From:* Carl Burn [mailto:burnsy at northcountrywoods.co.uk]
>>> >> >> *Sent:* Friday, January 14, 2011 5:35 AM
>>> >> >> *To:* geomoose-users at lists.sourceforge.net
>>> >> >> *Subject:* Re: [Geomoose-users] Setting up first geomoose app
>>> >> >> Hi, still banging up against a brick wall with this one. I have
>>> taken
>>> >> >> some
>>> >> >> advice and resolved the extent issues in my map file and xml
>>> file.
>>> I
>>> >> >> have
>>> >> >> also modified the map and xml files so that they are considerably
>>> >> >> simpler,
>>> >> >> figuring that if its simpler it will be easier to spot my
>>> mistakes. I
>>> >> >> have
>>> >> >> attached the two files to this mail, not sure if this is allowed
>>> on
>>> >> the
>>> >> >> listserver.
>>> >> >> Here is what else I have tried:
>>> >> >> 1. Ran the mapfile through shp2img and it is not generating any
>>> error
>>> >> >> messages at all, though the time to draw the layer comes in at
>>> 0.000s
>>> >> >> which
>>> >> >> seems odd to me.
>>> >> >> 2. Ran a get capabilities request on the map file and got the xml
>>> >> back,
>>> >> >> this is not reporting any errors.
>>> >> >> http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d
>>> >> :\ms4w\apps\geomoose2\maps\arcview\testshp.map<
>>> http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d:%5Cms4w%5Capps%5Cgeomoose2%5Cmaps%5Carcview%5Ctestshp.map%26SERVICE%3DWMS%26VERSION%3D1.1.1%26REQUEST%3DGetMap%26LAYERS%3Dtestlayer%26STYLES%3D%26SRS%3DEPSG:4326&BBOX=-990487.465830,-31957.211592,1696934.624449,1261986.757801&WIDTH=400&HEIGHT=600&FORMAT=image/png
>>> >> >> &SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
>>> >> >> 3. Ran a get map request to generate a map image, again I can see
>>> >> this
>>> >> >> without any errors.
>>> :\ms4w\apps\geomoose2\maps\arcview\testshp.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=testlayer&STYLES=&SRS=EPSG:4326&BBOX=-990487.465830,-31957.211592,1696934.624449,1261986.757801&WIDTH=400&HEIGHT=600&FORMAT=image/png<
>>> >> >> 4. Connected to the wms layer with QGIS as my client, the map
>>> image
>>> >> >> appears
>>> >> >> with no errors.
>>> >> >> I am totally lost at this point and have no idea why the map
>>> image
>>> is
>>> >> >> not
>>> >> >> appearing, any clues would be most welcome.
>>> >> >> Carl
>>> >> >> On Thu, Jan 13, 2011 at 9:32 PM, Brent Fraser
>>> >> >> wrote:
>>> >> >> And while you've got a <map-source> defined, I don't think
>>> there's
>>> a
>>> >> >> <Layer> set up to reference it.
>>> >> >> Brent
>>> >> >> > Carl,
>>> >> >> > One problem is that the coordinate system is defined as
>>> longlat,
>>> >> but
>>> >> >> the
>>> >> >> > extent is given is something other than decimal degrees:
>>> >> >> > EXTENT -990487.465830 -31957.211592 1696934.624449
>>> 1261986.757801
>>> >> >> > PROJECTION
>>> >> >> > 'init=epsg:4326'
>>> >> >> > 'proj=longlat'
>>> >> >> > 'ellps=WGS84'
>>> >> >> > 'datum=WGS84'
>>> >> >> > 'no_defs'
>>> >> >> > END
>>> >> >> > And in the mapbook as well.
>>> >> >> > Brent
>>> >> >> >> Hi,
>>> >> >> >> trying to get a basic app working in geomoose using our own
>>> data
>>> >> and
>>> >> >> I
>>> >> >> >> am
>>> >> >> >> getting a blank map area. I have set up a simple map file in
>>> the
>>> >> >> >> standard
>>> >> >> >> ms4w maps folder in a folder called ArcView, I have put my map
>>> >> file
>>> >> >> in
>>> >> >> >> to
>>> >> >> >> that folder and have tested it using a browser and can see a
>>> map
>>> >> and
>>> >> >> am
>>> >> >> >> able
>>> >> >> >> to download an xml document when I do a get capabilities
>>> request.
>>> >> >> >> The map file is as follows:
>>> >> >> >> ============== MAP FILE =======================
>>> >> >> >> MAP
>>> >> >> >> NAME "TESTMAP"
>>> >> >> >> # Map image size
>>> >> >> >> SIZE 800 800
>>> >> >> >> UNITS INCHES
>>> >> 1261986.757801
>>> >> >> >> FONTSET "../fonts/fontset.list"
>>> >> >> >> SYMBOLSET "../symbols/symbol.sym"
>>> >> >> >> PROJECTION
>>> >> >> >> 'init=epsg:4326'
>>> >> >> >> 'proj=longlat'
>>> >> >> >> 'ellps=WGS84'
>>> >> >> >> 'datum=WGS84'
>>> >> >> >> 'no_defs'
>>> >> >> >> END
>>> >> >> >> IMAGECOLOR 255 255 255
>>> >> >> >> IMAGEQUALITY 95
>>> >> >> >> IMAGETYPE jpeg
>>> >> >> >> OUTPUTFORMAT
>>> >> >> >> NAME jpeg
>>> >> >> >> DRIVER 'GD/JPEG'
>>> >> >> >> MIMETYPE 'image/jpeg'
>>> >> >> >> IMAGEMODE RGBA
>>> >> >> >> EXTENSION 'jpeg'
>>> >> >> >> END
>>> >> >> >> LEGEND
>>> >> >> >> STATUS ON
>>> >> >> >> KEYSIZE 18 12
>>> >> >> >> LABEL
>>> >> >> >> TYPE BITMAP
>>> >> >> >> SIZE MEDIUM
>>> >> >> >> COLOR 0 0 89
>>> >> >> >> END
>>> >> >> >> END
>>> >> >> >> WEB
>>> >> >> >> IMAGEPATH '/tmp/'
>>> >> >> >> IMAGEURL '/tmp/'
>>> >> >> >> METADATA
>>> >> >> >> 'ows_title' 'TESTMAP'
>>> >> >> >> 'ows_onlineresource' 'http://www.*ourserver*
>>> >> >> >> .com:2112/cgi-bin/mapserv.exe?map=testshp.map'
>>> >> >> >> 'ows_srs' 'EPSG:4326'
>>> >> >> >> END
>>> >> >> >> TEMPLATE 'foo'
>>> >> >> >> END
>>> >> >> >> LAYER
>>> >> >> >> NAME 'RECTANGLES'
>>> >> >> >> TYPE POLYGON
>>> >> >> >> DUMP true
>>> >> >> >> TEMPLATE fooOnlyForWMSGetFeatureInfo
>>> >> 1261986.757801
>>> >> >> >> DATA
>>> >> 'D:/ms4w/apps/geomoose2/maps/ArcView/seamless_rectangle.shp'
>>> >> >> >> METADATA
>>> >> >> >> 'ows_title' 'rectangles'
>>> >> >> >> END
>>> >> >> >> STATUS OFF
>>> >> >> >> TRANSPARENCY 100
>>> >> >> >> PROJECTION
>>> >> >> >> 'init=epsg:4326'
>>> >> >> >> 'proj=longlat'
>>> >> >> >> 'ellps=WGS84'
>>> >> >> >> 'datum=WGS84'
>>> >> >> >> 'no_defs'
>>> >> >> >> END
>>> >> >> >> CLASS
>>> >> >> >> NAME 'seamless_rectangle'
>>> >> >> >> STYLE
>>> >> >> >> WIDTH 1
>>> >> >> >> OUTLINECOLOR 0 0 0
>>> >> >> >> COLOR 149 170 154
>>> >> >> >> END
>>> >> >> >> END
>>> >> >> >> END
>>> >> >> >> END
>>> >> >> >> =============== END OF MAP FILE=================
>>> >> >> >> The map book .xml is as follows, just a commented out version
>>> of
>>> >> the
>>> >> >> >> original one:
>>> >> >> >> ============== MAPBOOK.XML ===================
>>> >> >> >> <?xml version="1.0"?>
>>> >> >> >> <mapbook version="2.0">
>>> >> >> >> <configuration>
>>> >> >> >> <param name="links_bar_html"><![CDATA[Perfect
>>> timing
>>> >> for
>>> >> >> >> some
>>> >> >> >> damn CDATA "all" of 'its' here <&>]]></param>
>>> >> >> >> <param
>>> name="layer_controls.unfade.on">false</param>
>>> >> >> >> <!-- <param name="zoomto['Jump To:']"><![CDATA[
>>> >> >> >> 'Dakota County' :
>>> >> [521238.614537864,4924218.86673578,473921.947801381,4974430.36885032],
>>> >> >> >> 'Parcel Data' :
>>> >> >> >> [497205.409367,4923984.423582,477595.805945,4941970.52988],
>>> >> >> >> 'Full State of MN' :
>>> >> >> >> [189783.560000,4816309.330000,761653.524114,5472346.500000]
>>> >> >> >> ]]></param> -->
>>> >> >> >> <param
>>> name="max_extent">-1053325.991731,-63036.027500,1763261.991731,1293098.927500</param>
>>> >> >> >> <param
>>> name="initial_extent">-990487.465830,-31957.211592,1696934.624449,1261986.757801</param>
>>> >> >> >> <param name="layer_controls.legend.on">false</param>
>>> >> >> >> <param
>>> name="mapserver_url">/cgi-bin/mapserv.exe</param>
>>> >> >> >> <param
>>> >> name="mapfile_root">/ms4w/apps/geomoose2/maps/</param>
>>> >> >> >> <param name="projection">EPSG:4326</param>
>>> >> >> >> <param name="layer_controls.up.on">false</param>
>>> >> >> >> <param name="layer_controls.down.on">false</param>
>>> >> >> >> <param name="layer_controls.legend.on">true</param>
>>> >> >> >> <param name="drawing_tools.default_fill">red</param>
>>> >> >> >> <param
>>> name="drawing_tools.default_stroke">yellow</param>
>>> >> >> >> <param name="drawing_tools.default_opacity">1</param>
>>> >> >> >> <param name="group_checkboxes">false</param>
>>> >> >> >> <param name="default_tab">Catalog</param>
>>> >> >> >> <param name="catalog_name">Catalog</param>
>>> >> >> >> <param
>>> name="show_service_settings_in">Information</param>
>>> >> >> >> <param name="show_results_in">Information</param>
>>> >> >> >> <param name="tabs"><![CDATA[
>>> >> >> >> 'Catalog' : 'catalog-tab',
>>> >> >> >> 'Information' : 'information-tab',
>>> >> >> >> 'Custom' : 'custom-tab'
>>> >> >> >> ]]></param>
>>> >> >> >> <param name="ground_units">km</param>
>>> >> >> >> <param
>>> >> >> >> name="scales">.5,1,4,8,16,24,32,64,128,270,550,1000</param>
>>> >> >> >> <param name="reference_map.enabled">false</param>
>>> >> >> >> <param name="coordinate_display.usng">false</param>
>>> >> >> >> <param name="jumpto_scales"><![CDATA[
>>> >> >> >> '1:50000' : 50000,
>>> >> >> >> '1:24000' : 24000,
>>> >> >> >> '1:10000' : 10000,
>>> >> >> >> '1:5000' : 5000
>>> >> >> >> ]]></param>
>>> >> >> >> </configuration>
>>> >> >> >> The mapping services define the source of the mapping
>>> >> data.
>>> >> >> >> <map-source name="highlight" type="mapserver">
>>> >> >> >> <file/>
>>> >> >> >> <layer name="all"/>
>>> >> >> >> </map-source>
>>> >> >> >> <map-source name="TESTMAP" type="mapserver">
>>> >> >> >> <file>./ArcView/testshp.map</file>
>>> >> >> >> <layer name="rectangles"/>
>>> >> >> >> </map-source>
>>> >> >> >> <!-- <map-source name="borders" type="mapserver"
>>> >> >> >> reference="true">
>>> >> >> >> <file>./demo/statedata/basemap.map</file>
>>> >> >> >> <layer name="all"/>
>>> >> >> >> </map-source>
>>> >> >> >> <map-source name="iastate" type="wms" tiled="false"
>>> >> >> >> projection="EPSG:900913" width="512" height="512">
>>> >> >> >> <url>
>>> >> >> http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi
>>> >> >> >> </url>
>>> >> >> >> <layer name="nexrad-n0r"/>
>>> >> >> >> <param name="format" value="image/jpeg"/>
>>> >> >> >> <param name="TRANSPARENT" value="TRUE"/>
>>> >> >> >> </map-source>
>>> >> >> >> <map-source name="metbase" type="ags" >
>>> >> >> >> <url>
>>> http://gis.metc.state.mn.us/ArcGIS/rest/services/BaseLayer/UTMBaseMap/MapServer/export
>>> >> >> >> </url>
>>> >> >> >> <layer name="Met Council Base Map Layers" />
>>> >> >> >> <param name="FORMAT" value="JPG"/>
>>> >> >> >> </map-source>
>>> >> >> >> <map-source name="lmic" type="wms" tiled="false">
>>> >> >> >> <url>http://geoint.lmic.state.mn.us/cgi-bin/wms</url>
>>> >> >> >> <layer name="fsa2008"/>
>>> >> >> >> <layer name="bw1997"/>
>>> >> >> >> </map-source>
>>> >> >> >> <map-source name="usgs_doq" type="wms" tiled="false"
>>> >> >> >> projection='EPSG:26915'>
>>> >> >> >> <url>http://terraservice.net/ogcmap.ashx?</url>
>>> >> >> >> <layer name="DOQ"/>
>>> >> >> >> </map-source>
>>> >> >> >> <map-source name="usgs_drg" type="wms" tiled="false"
>>> >> >> >> <layer name="DRG"/>
>>> >> >> >> </map-source>
>>> >> >> >> <map-source name="reference" type="wms" tiled="false"
>>> >> >> >> reference="true">
>>> >> >> >> <layer name="fsa2008" reference="true" />
>>> >> >> >> </map-source> -->
>>> >> >> >> <service name="print" title="Print Map">
>>> >> >> >> <step type="input">
>>> >> >> >> <url>php/print.php</url>
>>> >> >> >> <input type="print_info" name="layers"/>
>>> >> >> >> <input type="extent" name="extent"/>
>>> >> >> >> <input type="sketches" name="sketches"/>
>>> >> >> >> <input type="user" name="title" title="Map
>>> >> >> >> Title">Map</input>
>>> >> >> >> <input type="hidden" name="date" title="Map
>>> >> >> >> Date">true</input>
>>> >> >> >> <input type="select" name="template" title="Output
>>> >> >> Template:
>>> >> >> >> <option value="letter_landscape">Letter -
>>> >> >> >> Landscape</option>
>>> >> >> >> <option value="letter_portrait">Letter -
>>> >> >> >> Portrait</option>
>>> >> >> >> <option value="poster_landscape">11" x 17" -
>>> >> >> >> Landscape</option>
>>> >> >> >> <option value="poster_portrait">11" x 17" -
>>> >> >> >> Portrait</option>
>>> >> >> >> </input>
>>> >> >> >> <input type="select" name="quality" title="Image
>>> >> Quality:
>>> >> >> >> <option value="2">Higher</option>
>>> >> >> >> <option value="3">Highest</option>
>>> >> >> >> <option value="1">Standard</option>
>>> >> >> >> </input>
>>> >> >> >> <input type="select" name="scale" title="Preserve
>>> >> Scale:
>>> >> >> >> <option value="preserve">Yes</option>
>>> >> >> >> <option value="no">No</option>
>>> >> >> >> </input>
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> <service name="identify" title="Identify" display="false">
>>> >> >> >> <url>php/identify.php</url>
>>> >> >> >> <step type="spatial" name="shape" line="false"
>>> >> >> polygon="false"
>>> >> >> >> jump-start="true" default="point">
>>> >> >> >> <input type="visiblelayers" name="layers"/>
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> <service name="birdseye" display="false" target="_blank">
>>> >> >> >> <url>php/birdseye.php</url>
>>> >> >> >> <step type="spatial" name="xy" line="false"
>>> >> polygon="false"
>>> >> >> >> jump-start="true" default="point" format="delim"
>>> >> >> reproject="EPSG:4326">
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> <service name="streetview" display="false" target="_blank">
>>> >> >> >> <url>php/streetview.php</url>
>>> >> polygon="false"
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> <service name="feature_report" display="false">
>>> >> >> >> <url>php/feature_report.php</url>
>>> >> >> >> <input type="hidden" name="layers" value="lmic/fsa"/>
>>> >> >> >> <input type="hidden" name="src"/>
>>> >> >> >> <input type="hidden" name="PIN"/>
>>> >> >> >> </service>
>>> >> >> >> <service name="select" title="Select">
>>> >> >> >> <url>php/select.php</url>
>>> >> >> >> <!-- Send a selection shape + the visible layers list
>>> to
>>> >> the
>>> >> >> >> service
>>> >> >> >> <step type="spatial" showTools="true" name="shape"
>>> >> >> line="true"
>>> >> >> >> polygon="true" point="true" default="polygon"
>>> edit-polygon="false"
>>> >> >> >> pan="false" jump-start="true">
>>> >> >> >> <header><![CDATA[Create a selection area by
>>> clicking
>>> >> on
>>> >> >> the
>>> >> >> >> map.]]></header>
>>> >> >> >> Option values should be the mapbook path to the
>>> >> >> layer.
>>> >> >> >> This only supports 'mapserver'-type layers.
>>> >> >> >> <input type="select" name="select_layer"
>>> >> title="Select:">
>>> >> >> >> <option
>>> value="parcels/parcels">Parcels</option>
>>> >> >> >> </input>
>>> >> >> >> <input type="user" name="shape_buffer"
>>> title="Buffer
>>> >> >> >> Selection
>>> >> >> >> Shape (ft)">0</input>
>>> >> >> >> <input type="select" name="query_layer"
>>> title="Using
>>> >> >> >> Features
>>> >> >> >> In">
>>> >> >> >> <option
>>> >> >> >> </input>
>>> title="Buffer
>>> >> >> >> Selection
>>> >> >> >> <footnote><![CDATA[
>>> >> >> >> ]]></footnote>
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> <!-- this is called after a standard select in order to
>>> buffer
>>> >> >> the
>>> >> >> >> previous selection -->
>>> >> >> >> <service name="buffered_select_followup" title="Buffered
>>> >> Select">
>>> >> >> >> <step type="input">
>>> >> >> >> <input type="hidden" name="shape"/>
>>> >> >> >> <input type="hidden" name="select_layer"/>
>>> >> >> >> <input type="hidden" name="query_layer"/>
>>> >> >> >> <input type="hidden" name="shape_buffer"/>
>>> >> >> >> <input type="user" name="selection_buffer"
>>> >> title="Buffer
>>> >> >> >> Features By: "/>
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> <service name="buffered_select" title="Buffered Select">
>>> to
>>> >> the
>>> >> >> >> service
>>> >> >> line="true"
>>> >> >> >> pan="false">
>>> clicking
>>> >> on
>>> >> >> the
>>> >> >> >> map.]]></header>
>>> >> >> layer.
>>> title="Select
>>> >> >> >> features
>>> >> >> >> from:">
>>> >> >> >> <option
>>> >> >> >> </input>
>>> >> title="Buffer
>>> >> >> >> Selected Features (ft)">0</input>
>>> >> >> >> <!-- <input type="user" name="shape_buffer"
>>> >> title="Buffer
>>> >> >> >> Selection Shape (ft)">0</input>
>>> title="Using
>>> >> >> >> Features
>>> >> >> >> In">
>>> >> >> >> <option
>>> >> >> >> </input>
>>> >> >> >> <footnote><![CDATA[
>>> >> >> >> ]]></footnote>
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> <service name="popups" display="false">
>>> >> >> >> <url>php/popups.php</url>
>>> >> >> polygon="false"
>>> >> >> >> <header><![CDATA[
>>> >> >> >> Click on the map to show a popup about the
>>> features.
>>> >> >> >> ]]></header>
>>> >> >> >> <input type="hidden" name="layer"/>
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> <service name="geocode_address" title="Geocode Address">
>>> >> >> >> <url>php/geocode.php</url>
>>> >> >> >> <step type="input">
>>> >> >> >> <input type="user" name="address" title="Enter
>>> >> Address:
>>> >> >> >> <input type="hidden" name="googlekey"
>>> value="ABQIAAAA4Q-VLyIpwp3L8M9DIzKb2BT2yXp_ZAY8_ufC3CFXhHIE1NvwkxRe8Hd6FR51Hvb-Fvd-wGjiDZDC4w"/>
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> <service name="search_parcels">
>>> >> >> >> <url>php/query.php</url>
>>> >> >> >> <step type="input">
>>> >> >> >> <input type="hidden" name="highlight"
>>> value="true"/>
>>> >> >> >> <input type="hidden" name="mode" value="search"/>
>>> >> >> >> <input type="hidden" name="layer0"
>>> >> >> value="parcels/parcels"/>
>>> >> >> >> <input type="hidden" name="template0"
>>> >> value="itemquery"/>
>>> >> >> >> <input type="select" name="fieldname0"
>>> title="Search
>>> >> >> By:">
>>> >> >> >> <option value="OWNER_NAME">Owner</option>
>>> >> >> >> <option value="PIN">Parcel ID</option>
>>> >> >> >> </input>
>>> >> >> >> <input type="select" name="comparitor0"
>>> title="That:
>>> >> >> >> <option value="like-icase">Contains</option>
>>> >> >> >> <option value="right-like-icase">Begins
>>> >> With</option>
>>> >> >> >> <option value="eq-str">Matches Exactly</option>
>>> >> >> >> </input>
>>> >> >> >> <input type="user" name="value0" title=""/>
>>> >> >> >> <input type="hidden" name="fieldname1"
>>> >> >> value="FIN_SQ_FT"/>
>>> >> >> >> <input type="select" name="operator1">
>>> >> >> >> <option value="or">OR</option>
>>> >> >> >> <option value="and">AND</option>
>>> >> >> >> </input>
>>> >> >> >> <input type="select" name="comparitor1"
>>> title="Having
>>> >> >> Fin.
>>> >> >> >> Sq.
>>> >> >> >> Ft. ">
>>> >> >> >> <option value="gt">Greater Than</option>
>>> >> >> >> <option value="eq">Equal To</option>
>>> >> >> >> <option value="lt">Less Than</option>
>>> >> >> >> </input>
>>> >> >> >> <input type="user" name="value1" title=""/>
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> The catalog defines how the layers will be displayed in
>>> >> the
>>> >> >> >> catalog
>>> >> >> >> tab.
>>> >> >> >> <layer-controls>
>>> >> >> >> <layer-control name="popups" service-name="popups"
>>> >> >> >> layer-input="layer" on="false" tip="Show Popups for %LAYER%"/>
>>> >> >> >> </layer-controls>
>>> >> >> >> <catalog>
>>> >> >> >> <!-- <layer title="overallmap" src="parcels/parcels"
>>> >> >> status="on"
>>> >> >> >> popups="true" minscale="0" maxscale="150000" metadata="true" >
>>> >> >> >> <metadata>http://www.aqua3.com</metadata>
>>> >> >> >> </layer>
>>> >> >> >> <layer title="City and County Boundaries"
>>> >> src="borders/all"
>>> >> >> >> status="on"/>
>>> >> >> >> <layer title="Weather Radar" src="iastate/nexrad-n0r"
>>> >> >> >> status="off"
>>> >> >> >> legend="false"/>
>>> >> >> >> <group title="Backgrounds" expand="true"
>>> multiple="false">
>>> >> >> >> <layer title="Metro Base Map" src="metbase/Met
>>> Council
>>> >> >> Base
>>> >> >> >> Map
>>> >> >> >> Layers" status="on" legend="false" />
>>> >> >> >> <layer title="2008 Aerial Photographs"
>>> >> src="lmic/fsa2008"
>>> >> >> >> status="off" legend="false" />
>>> >> >> >> <layer title="1997 Aerial Photographs"
>>> >> src="lmic/bw1997"
>>> >> >> >> <layer title="USGS DOQs" src="usgs_doq/DOQ"
>>> >> status="off"
>>> >> >> >> fade="true" unfade="true" legend="false" />
>>> >> >> >> <layer title="USGS Topo Quads" src="usgs_drg/DRG"
>>> >> >> >> status="off"
>>> >> >> >> <layer title="None" src=" " status="off"
>>> >> legend="false"
>>> >> >> >> fade="false" unfade="false" />
>>> >> >> >> </group> -->
>>> >> >> >> </catalog>
>>> >> >> >> The toolbar defines which services are referneces in
>>> the
>>> >> >> toolbar
>>> >> >> >> <toolbar>
>>> >> >> >> <tool name="previous" title="Previous Extent"
>>> >> type="internal"
>>> >> >> >> action="previous" selectable="false"/>
>>> >> >> >> <tool name="next" title="Next Extent" type="internal"
>>> >> >> >> action="next"
>>> >> >> >> <tool name="fullextent" title="Zoom to Full Extent"
>>> >> >> >> type="internal"
>>> >> >> >> action="fullextent" selectable="false"/>
>>> >> >> >> <tool name="pan" title="Pan" type="internal"
>>> >> action="pan"/>
>>> >> >> >> <tool name="zoomin" title="Zoom In" type="internal"
>>> >> >> >> action="zoomin"
>>> >> >> >> selected="true"/>
>>> >> >> >> <tool name="zoomout" title="Zoom Out" type="internal"
>>> >> >> >> action="zoomout"/>
>>> >> >> >> <!-- <tool name="identify" title="Identify"
>>> >> type="service"
>>> >> >> >> service="identify" cursor="url('cursors/identify2.cur') 9
>>> >> >> >> 9,url('cursors/identify2.cur'),auto" /> -->
>>> >> >> >> <!-- <tool name="select" title="Select" type="service"
>>> >> >> >> service="select"/> -->
>>> >> >> >> <!-- <tool name="buffered_select" title="Buffered
>>> >> Select"
>>> >> >> >> type="service" service="buffered_select"/> -->
>>> >> >> >> <!-- <tool name="clear" title="Clear Selection"
>>> >> >> >> type="javascript"
>>> >> >> >> selectable="false">
>>> >> >> >> GeoMOOSE.changeLayerVisibility('highlight/all',
>>> >> false);
>>> >> >> >> </tool> -->
>>> >> >> >> <tool name="measure" title="Measure" type="internal"
>>> >> >> >> action="measure"/>
>>> >> >> >> <tool name="measurearea" title="Measure Area"
>>> >> type="internal"
>>> >> >> >> action="measurearea"/>
>>> >> >> >> <!-- <tool name="search_parcels" title="Search Parcels"
>>> >> >> >> type="service" service="search_parcels" selectable="false"/>
>>> >> >> >> <!-- <tool name="print" title="Print" type="service"
>>> >> >> >> service="print"
>>> >> >> >> selectable="false"/> -->
>>> >> >> >> <!-- <tool name="birdseye" title="Bird's Eye View"
>>> >> >> >> type="service"
>>> >> >> >> selectable="true" service="birdseye"/> -->
>>> >> >> >> <!-- <tool name="streetview" title="Google Street View"
>>> >> >> >> type="service" service="streetview" selectable="true"/> -->
>>> >> >> >> <!-- <tool name="geocode" title="Geocode Address"
>>> >> >> type="service"
>>> >> >> >> service="geocode_address" selectable="true"/> -->
>>> >> >> >> <!-- <drawer>
>>> >> >> >> <tool name="markup_tools" title="Sketch Tools"
>>> >> >> >> type="internal"
>>> >> >> >> action="none" selectable="false"/>
>>> >> >> >> <tool name="draw_polygon" title="Draw Polygon"
>>> >> >> >> type="internal"
>>> >> >> >> action="draw_polygon"/>
>>> >> >> >> <tool name="draw_line" title="Draw Line"
>>> >> type="internal"
>>> >> >> >> action="draw_line"/>
>>> >> >> >> <tool name="draw_point" title="Draw Point"
>>> >> >> type="internal"
>>> >> >> >> action="draw_point"/>
>>> >> >> >> <tool name="draw_remove" title="Remove Drawing"
>>> >> >> >> type="internal"
>>> >> >> >> action="draw_remove"/>
>>> >> >> >> <tool name="draw_edit" title="Edit Drawing"
>>> >> >> type="internal"
>>> >> >> >> action="draw_edit_shapes"/>
>>> >> >> >> <tool name="draw_edit_attributes" title="Edit
>>> >> Attributes"
>>> >> >> >> type="internal" action="draw_edit_attributes"/>
>>> >> >> >> <tool name="clear_drawings" title="Clear Drawings"
>>> >> >> >> type="internal" action="clear_drawings" selectable="false"/>
>>> >> >> >> </drawer> -->
>>> >> >> >> </toolbar>
>>> >> >> >> </mapbook>
>>> >> >> >> ============= END OF MAPBOOK.XML =============
>>> >> >> >> I have tried getting some error reporting out of firebug with
>>> >> little
>>> >> >> >> success, if anyone can help me spot what I have done wrong it
>>> >> would
>>> >> >> be
>>> >> >> >> much
>>> >> >> >> appreciated and I would be happy to supply the real url's to
>>> the
>>> >> >> server
>>> >> >> >> off-list.
>>> >> >> >> Cheers
>>> >> >> >> Carl
>>> >> >> >> Protect Your Site and Customers from Malware Attacks
>>> >> >> >> Learn about various malware tactics and how to avoid them.
>>> >> Understand
>>> >> >> >> malware threats, the impact they can have on your business,
>>> and
>>> >> how
>>> >> >> you
>>> >> >> >> can protect your company and customers by using code signing.
>>> http://p.sf.net/sfu/oracle-sfdevnl_______________________________________________
>>> >> >> >> Geomoose-users mailing list
>>> >> >> >> Geomoose-users at lists.sourceforge.net
>>> >> >> >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
>>> >> >> > Best Regards
>>> >> >> > Brent Fraser
>>> >> Understand
>>> >> >> > malware threats, the impact they can have on your business, and
>>> how
>>> >> >> you
>>> >> >> Best Regards
>>> >> >> Brent Fraser
>>> Understand
>>> how
>>> >> you
>>> >> Best Regards
>>> >> Brent Fraser
>>> > Learn about various malware tactics and how to avoid them. Understand
>>> > malware threats, the impact they can have on your business, and how
>>> you
>>> Best Regards
>>> Brent Fraser
> Best Regards
> Brent Fraser
Best Regards
Brent Fraser
More information about the Geomoose-users mailing list
