[Geomoose-users] Query.php and data types
Johan Forsman
Johan.Forsman at LA.GOV
Tue Jul 5 08:29:47 EDT 2011
All:
On GM 2.2, I am having some difficulty obtaining results from query.php using PostGIS as the datastore.
There are 2 fields from 1 table being searched. The user selects the analyte_code values from a dropdown and sample_collection_date bracketed values are typed in.
The query executes but returns no results.
I found the debug lines in the query.php source and uncommented those lines which revealed the FILTER string as:
analyte_code = 1005 and sample_collection_date >= 2009-12-31 and sample_collection_date <= 2011-07-01
If I isolate the values individually it appears that the values are passed to the database as integers, which results in data-type errors from the database.
For analyte_code:
Operator does not exist: character = integer.
And for sample_collection_date:
Operator does not exist: timestamp without time zone >= integer
Now that last error looks a little off; is the postqresql trying to interpret the string and do math?
The data are in fact stored in the database as "character" and "timestamp without time zone", respectively.
>From the SQL console I can issue
select *
from geodata.webmaps_mcl_violations
where
analyte_code = '1005' and
sample_collection_date >= '2009-12-31' and
sample_collection_date <= '2011-07-01';
which returns the expected results.
The hint from the sql console when the error is generated from the filter string is that I might need to add explicit type casts. If this is indeed the case, where do I add these? I experimented by adding single quotes in the query definition in the mapbook but those were escaped to \' which the database didn't care much for.
Please advise.
Thanks!
Johan Forsman
Geologist
Safe Drinking Water Program
Louisiana Department of Health and Hospitals
More information about the Geomoose-users
