[Geomoose-users] GeoMoose Mobile OpenLayers Control TouchNavigation
Dan Little danlittle at yahoo.com
Wed Jul 6 08:20:59 EDT 2011
There should be some sniffing happening.  Not by browser name, however, but by detecting whether the functionality is supported.  We may (in say, a 2.8 or 3.0 release) want to have a way of having a "mobile view" or at least some additional configuration parameters that allow the administrator to have a more mobile appropriate form of the application.
>________________________________
>From: Bob Basques <Bob.Basques at ci.stpaul.mn.us>
>To: Geomoose Support <geomoose-users at lists.sourceforge.net>; Michael J. (DOT) Reynolds <mike.reynolds at state.mn.us>; Dan Little <danlittle at yahoo.com>
>Sent: Tuesday, July 5, 2011 9:27 AM
>Subject: Re: [Geomoose-users] GeoMoose Mobile OpenLayers Control TouchNavigation
>I figured the touch stuff would make it's way through to GeoMoose at some point, just didn't know when exactly.  Nice to hear it's closer than I first thought.
>Question, is the activation of the Touch stuff all Browser (name) related, as in the GM app needs to figure out the browser, or will/should it be a configuration setup for a mobile (only?) service?
>bobb
>>>> Dan Little <danlittle at yahoo.com> wrote:
>I've been waiting for OL2.11 to come out of RC status.  Though I think RC1 may end up being the only RC.  I think the touch integration should work pretty smoothly.
>>Sent: Wednesday, June 29, 2011 3:00 PM
>>Michael,
>>You're definitely on the forefront of development here with respect to GeoMoose.
>>I'm seeing more interest in the Mobile support stuff for GeoMoose (and other OSS projects) lately, and I'm interested in what can be made to work here.
>>I have an IPAD now and an Android device on order.  Do you have a public facing site to demo/test from?  I don't have anything in the new GEOMOOSE code running on the outside right now, or I play there.   I could set up my own and add your changes too if need be.
>>bobb
>>>>> "Reynolds, Michael J. (DOT)" <mike.reynolds at state.mn.us> wrote:
>>I was wondering if anyone has created a good Mobile Touch version of Geomoose.  Is there a good way to do this?
>>I took a quick chop at it.  With a version of Goemoose 2.2. Downloaded the newest OpenLayers 2.11-rc1 to the htdocs folder.
>>Modified the index.html to load the openlayers.js from this new version’s folder.
>>In the compiled.js file I made the following change:
>>function configureMap () {
>>      CONFIGURATION.scales = CONFIGURATION.scales.sort().reverse();
>>      var options = {
>>            maxExtent : OpenLayers.Bounds.fromArray(CONFIGURATION.max_extent),
>>            controls : [new OpenLayers.Control.PanZoomBar(), new OpenLayers.Control.ScaleJumper({target: 'scale-jumper'}), new OpenLayers.Control.TouchNavigation({dragPanOptions: {enableKinetic: true }})],
>>            units: CONFIGURATION.ground_units,
>>            projection: new OpenLayers.Projection(CONFIGURATION.projection),
>>            displayProjection: new OpenLayers.Projection(CONFIGURATION.projection),
>>            fractionalZoom: CONFIGURATION.fractional_zoom
>>Specifically I added “, new OpenLayers.Control.TouchNavigation({dragPanOptions: {enableKinetic: true }})” to the controls array.
>>The site seemed to load up just fine.
>>The map panel now responds to touch gestures:
>>Double tap / reverse pinch = zoom in
>>Pinch = zoom out
>>Point drag = pan
>>Zoom to extent tool works.
>>Some of the navigation tools are not necessary now (magnifying glass, pan?)
>>The Identify tool does not work.  I think the way I added in the Touch Navigation or the existing geomoose tool management doesn’t allow the identify click to override the touch navigation on the map div.
>>Our goal is to make our Geomoose site compatible with Ipad/Safari devices and Android devices.
>>I don’t know what this breaks.  Does it break anything?
>>Anyone already pave this ground?
>>Michael Reynolds
>>(651) 775-5915
>>Traffic Engineering - Data Management
>>MnDot - Metro District
>>USNG: 15TVK8708484276
>>All of the data generated in your IT infrastructure is seriously valuable.
>>Why? It contains a definitive record of application performance, security
>>threats, fraudulent activity, and more. Splunk takes this data and makes
>>sense of it. IT sense. And common sense.
>>http://p.sf.net/sfu/splunk-d2d-c2
>>_______________________________________________
>>Geomoose-users mailing list
>>Geomoose-users at lists.sourceforge.net
>>https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110706/c19525f6/attachment.html
More information about the Geomoose-users mailing list
