[Geomoose-users] How to add a new line to postgis db in degrees?
pinchitirabassi
pinchitirabassi at gmail.com
Tue Jul 12 18:16:37 EDT 2011
Hi, I've set up geomoose and I followed the instructions on the website. I
created a tool to add lines, and they are added to the database, but I have
a database with information in the EPSG:4326 SRID, and the insertion is made
in meters. I need to configure it so as to insert linestrings in degrees.
So far, I have changed some lines in the mapbook:
EPSG:4326
dd
But this didn't do anything.
I set a wms map-source and it works perfectly:
<map-source name="street_editor" type="wms" tiled="true"
projection='EPSG:900913'>
<url>http://localhost/cgi-bin/mapserv</url>
<layer name="streets"/>
</map-source>
I don't know if it has something to do with the problem.
Hope you can help.
Pinchi
View this message in context: http://geomoose-users.964460.n3.nabble.com/How-to-add-a-new-line-to-postgis-db-in-degrees-tp3164035p3164035.html
Sent from the Geomoose-users mailing list archive at Nabble.com.
More information about the Geomoose-users
