[Geomoose-users] Print map and results table on same document
Brian Fischer bfischer at houstoneng.com
Wed Jul 13 14:34:53 EDT 2011
We did some custom work for Door County with Map reports.  Select some parcels and you will see the options for the reports.  The soils map is pretty cool.  http://map.co.door.wi.us/map/
The code is pretty custom to their application and data.
Brian Fischer
GIS Project Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | F 763.493.5572
From: Bistrais, Bob [mailto:Bob.Bistrais at maine.gov]
Sent: Wednesday, July 13, 2011 12:20 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Print map and results table on same document
Has anyone ever built a template or done any coding which will place a query/selection results table onto a map document?  As you all know, we can generate a printed map, and we can print the table of results.  We would like to be able to have both on the same printable document.  Has this been done by anyone already, and would you be willing to share advice and/or code?
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110713/447d65a3/attachment.html
More information about the Geomoose-users mailing list
