[Geomoose-users] caching and other ways to increase performance
Dan Little
danlittle at yahoo.com
Sat Jul 30 23:16:41 EDT 2011
MapProxy is a much better solution as it will use stored tiles to generate scaled images. This gets the tiled sources for the google like mapping and interfaces and gets the pyramiding benefits of Bob's solution.
>________________________________
>From: Brian Fischer <bfischer at houstoneng.com>
>To: "Bistrais, Bob" <Bob.Bistrais at maine.gov>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
>Sent: Friday, July 29, 2011 3:28 PM
>Subject: Re: [Geomoose-users] caching and other ways to increase performance
>We have used Tilecache with GeoMOOSE a little bit. Seems tilecache is dying a bit in favor of GEoWebCache and MapProxy.
>We have also used ESRI rest map caches. There are limitations with these in that they are really only useful for basemap layers where you don’t need to do identify, selection and searches on them. The other complication is GeoMOOSE has very limited support for using these type of map sources with the print service. As of now the only one that works is ESRI REST services.
>I’ve also been meaning to look into MapProxy (http://mapproxy.org/). I’m hoping to learn more about that at FOSS4G.
>Hope this helps.
>Brian Fischer, CFM
>GIS Manager
>Houston Engineering, Inc.
>O763.493.4522 | D 763.493.6664 | M 763.229.2734
>From:Bistrais, Bob [mailto:Bob.Bistrais at maine.gov]
>Sent: Friday, July 29, 2011 2:36 PM
>To: geomoose-users at lists.sourceforge.net
>Subject: [Geomoose-users] caching and other ways to increase performance
>I was wondering what anyone was doing, with regard to caching tiles or other ways to boost performance in GeoMoose applications? While our current applications are performing well in GeoMoose, we’re looking ahead as applications get more complex and bloated with data. Has anyone done anything with GeoWebCache, for example, or some other means?
>Got Input? Slashdot Needs You.
>Take our quick survey online. Come on, we don't ask for help often.
>Plus, you'll get a chance to win $100 to spend on ThinkGeek.
>http://p.sf.net/sfu/slashdot-survey
>_______________________________________________
>Geomoose-users mailing list
>Geomoose-users at lists.sourceforge.net
>https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110730/15900502/attachment.html
More information about the Geomoose-users
