[Geomoose-users] Problems with geocoding
Bistrais, Bob Bob.Bistrais at maine.gov
Fri Jun 10 15:24:38 EDT 2011
I'm working on a modified geocode php file which will use our E911
address locator.  Once a point is located, the coordinates are used to
select a parcel using a queryByPoint.  I am able to get what look like
valid coordinates, but I keep getting an error and 0 features when I try
the query.  I'm not sure what's going on here.  The address locator and
the data layer are both in UTM Zone 19N (EPSG 26919), so I don't think
that's the issue, but who knows.
Here is some of the code, I'm appreciative of suggestions:
//Temporarily hard-coded coordinates:
$xCoord = 438949;
$yCoord = 4907614;
$point = ms_newPointObj();
$point->setXY($xCoord,$yCoord);
$selectLayer->queryByPoint($point,MS_SINGLE,200);
$numResults = $selectLayer->getNumResults();
print "num results=".$numResults;
---When run, the error message is this:
Warning: [MapServer Error]: msQueryByPoint(): No matching record(s)
found. in C:\ms4w\apps\geoparcels\htdocs\php\geocode.php on line 163
num results=0
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110610/aebd0b54/attachment.html
More information about the Geomoose-users mailing list
