[Geomoose-users] Feature editor, error missing required field
Dara Olson dolson at glifwc.org
Mon Jun 20 13:22:40 EDT 2011
It was my bad.  I had tried to rename/create new tables when everything was not working in the beginning and was pointing the edit and delete feature to the incorrect table name.  Sorry, but everything is working smoothly now.  Thanks so very much for your time!
Dara
  ----- Original Message -----
  To: Dara Olson
  Cc: geomoose-users at lists.sourceforge.net
  Sent: Monday, June 20, 2011 12:09 PM
  Subject: Re: [Geomoose-users] Feature editor, error missing required field
  What does your ini file contain?
Best Regards,
Brent Fraser
  On 6/20/2011 10:57 AM, Dara Olson wrote:
    After making the suggested edits, I can successfully add a feature.  I am unable to edit the point or delete an existing point.  If I attempt to edit the point, it gives the same prior error of "Missing required field:" and if I try to delete an existing point it gives me an error of, "No Feature ID specified to delete."  Below is the information contained within the HTML.
    <tr>
    <td><a href="javascript:GeoMOOSE.startService('modify_permit_comments', {'feature:gid' : '[gid]','feature:label' : '[label]','feature:permit_number' : '[permit_number] ','feature:file_name' : '[file_name]','feature:type_of_permit' : '[type_of_permit]', 'feature:wbic' : '[wbic]', 'feature:description' : '[description]', 'feature:pdf_name' : '[pdf_name]', 'feature:document_link' : '[document_link]', 'feature:georef_protocol' : '[georef_protocol]'})">Edit</a></td>
    <td><a href="javascript:if(confirm('Are you sure you want to delete this?')){GeoMOOSE.startService('delete_permit_comments',{'feature:gid':'[gid]'});}">Delete</a></td>
    </tr>
    I am assuming that there must be something incorrect somewhere. Has anyone ran into this or have any additional suggestions.  Thank you in advance for your time!
    Dara
      To: dolson at glifwc.org
      Sent: Thursday, June 16, 2011 11:03 AM
      It shouldn't be required.  I'll file a ticket.
      Best Regards,
      Brent Fraser
      On 6/16/2011 9:45 AM, dolson at glifwc.org wrote:
      > It worked!  I added it to the INI file and it added successfully.
      > Thank you so very much!
      > Dara
      >> Hmm.  You could try adding
      >> required_for_create=permit_number
      >> required_for_update=permit_number
      >> to your Layer.ini file...  I can't see anything obvious in your files or
      >> in editor.php...
      >> Best Regards,
      >> Brent Fraser
      >> On 6/15/2011 2:43 PM, Dara Olson wrote:
      >>> Greetings.
      >>> I am having some problems with the feature editor setup.  When I go to
      >>> add a point feature it says, "Missing required field:", but no field
      >>> is listed after the error.  There seems to be no errors showing up in
      >>> any of the logs either.  Does anyone know why I might be getting this
      >>> error?  Below is the setup for the feature and editor.  We are running
      >>> GeoMoose 2.2.
      >>> Any help or suggestions would be greatly appreciated.
      >>> Miigwech!
      >>> Dara
      >>> _Table:_
      >>> CREATE TABLE permits.glifwc_permit_comments_points
      >>>    gid serial NOT NULL,
      >>>    file_name character varying,
      >>>    description character varying,
      >>>    georef_protocol character varying,
      >>>    pdf_name character varying,
      >>>    document_link character varying,
      >>>    permit_number character varying,
      >>>    the_geom900913 geometry,
      >>>    date_lm date,
      >>>    wbic character varying,
      >>>    type_of_permit character varying,
      >>>    CONSTRAINT glifwc_prior_acoe_comments_pkey PRIMARY KEY (gid),
      >>>    CONSTRAINT enforce_dims_the_geom900913 CHECK
      >>> (st_ndims(the_geom900913) = 2),
      >>>    CONSTRAINT enforce_srid_the_geom900913 CHECK
      >>> (st_srid(the_geom900913) = 900913)
      >>> _Sequence and register:_
      >>> A sequence was set up, permits.glifwc_permit_comments_points_gid_seq
      >>> and an entry in the "geometry_columns" table for field
      >>> "the_geom900913", 900913, POINT.
      >>> _Mapfile definition:_
      >>> LAYER # GLIFWC Permit Comments
      >>>       NAME "glifwc_permit_comment_points"
      >>>       TYPE POINT
      >>>       STATUS ON
      >>>       CONNECTIONTYPE postgis
      >>>       CONNECTION "host=localhost dbname=xxxxx user=xxxxx password=xxxxx"
      >>>       PROCESSING "CLOSE_CONNECTION=DEFER"
      >>>       DATA "the_geom900913 FROM (SELECT *, ASTEXT(the_geom900913) AS
      >>> wkt_geometry
      >>>       FROM permits.glifwc_permit_comment_points) AS
      >>> glifwc_permit_comment_points using unique gid using srid=900913"
      >>>       PROJECTION
      >>>            "init=epsg:900913"
      >>>       END
      >>>       TOLERANCE 6
      >>>       CLASS
      >>>            NAME "GLIFWC Permit Comments"
      >>>            SYMBOL "..\..\icons\comments.gif"
      >>>            TEMPLATE "identify.html"
      >>>       END
      >>>       METADATA
      >>>            "identify_record" "identify.html"
      >>>       END
      >>> END # GLIFWC Permit Comments
      >>> The layer was successfully added to the project and displays correctly.
      >>> _Layer INI file:_
      >>> host=localhost
      >>> dbname=xxxxx
      >>> username=xxxxx
      >>> password=xxxxx
      >>> tablename=permits.glifwc_permit_comment_points
      >>> geometry_column=the_geom900913
      >>> primary_key_column=gid
      >>> primary_key_sequence=permits.glifwc_permit_comment_points_gid_seq
      >>> srid=900913
      >>> layerpath=glifwc_permit_comment/glifwc_permit_comment_points
      >>> _Service:_
      >>> <service name="add_permit_comment">
      >>> <url>php/editor.php</url>
      >>> <step type="spatial" name="feature:the_geom900913" line="false"
      >>> polygon="false" point="true" default="point">
      >>> </step>
      >>> <step type="input">
      >>> <input type="hidden" name="op" value="create"/>
      >>> <input type="hidden" name="table" value="glifwc_permit_comment_points"/>
      >>> <input type="user" name="feature:permit_number" title="Permit Number:"
      >>> <input type="user" name="feature:file_name" title="File Name:" />
      >>> <input type="select" name="feature:type_of_permit" title="Type of
      >>> Permit:">
      >>> <option value="APM Permit">APM Permit</option>...
      >>> </input>
      >>> <input type="user" name="feature:wbic" title="WBIC if applicable:"/>
      >>> <input type="user" name="feature:description" title="Description:"/>
      >>> <input type="user" name="feature:pdf_name" title="PDF Name:"/>
      >>> <input type="user" name="feature:document_link" title="Link to
      >>> Document:"/>
      >>> <input type="select" name="feature:georef_protocol"
      >>> title="Georeference Protocol:">
      >>> <option value="digitized by hand">Digitized by Hand</option>...
      >>> </input>
      >>> </step>
      >>> </service>
      >>> EditLive Enterprise is the world's most technically advanced content
      >>> authoring tool. Experience the power of Track Changes, Inline Image
      >>> Editing and ensure content is compliant with Accessibility Checking.
      >>> http://p.sf.net/sfu/ephox-dev2dev
      >>> Geomoose-users mailing list
      >>> Geomoose-users at lists.sourceforge.net
      >>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110620/5246d242/attachment.html
More information about the Geomoose-users mailing list
