[Geomoose-users] itemquery in gm 2.4? MS4W 3.0.1
Dan Little
danlittle at yahoo.com
Fri Jun 24 08:21:20 EDT 2011
What version of MapServer is on MS4W 3.0.1? Are you using Firebug? Is there any error in the HTML source?
>________________________________
>From: Michael Neimeyer <mike at gisrangers.com>
>To: geomoose-users at lists.sourceforge.net
>Sent: Tuesday, June 21, 2011 10:53 AM
>Subject: Re: [Geomoose-users] itemquery in gm 2.4? MS4W 3.0.1
>I am having this same issue with the 2.4 install. Has anyone found a solution so the templates will populate on the results tab?
>Thanks!
>Mike
>Mike Neimeyer
>GIS Project Manager
>GIS Rangers, LLC.
>2434 Virginia Circle
>Roseville, MN. 55113
>(M) 612.695.7325
>On Wed, Jun 15, 2011 at 2:12 PM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
>>Hello,
>>I can get the itemquery inGeomoose2.4 to highlight the correct results. HoweverHTML templates do not get displayed, all I see on the search pane on the right side is“GeoMOOSE Item Query Results.” Does anyone have any tipsto get the searches to work?
>>Environment:
>>Fresh install of MS4W 3.0.1. I also tested3.0.2
>>Fresh install of the GeoMoose 2.4 Dakota County Demo from the website.
>>No customizations were made.
>>Thanks
>>Mark Volz
>>EditLive Enterprise is the world's most technically advanced content
>>authoring tool. Experience the power of Track Changes, Inline Image
>>Editing and ensure content is compliant with Accessibility Checking.
>>http://p.sf.net/sfu/ephox-dev2dev
>>_______________________________________________
>>Geomoose-users mailing list
>>Geomoose-users at lists.sourceforge.net
>>https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110624/e2e64b92/attachment.html
More information about the Geomoose-users
