[Geomoose-users] reference map at 2.4 fails
Dan Little danlittle at yahoo.com
Fri Jun 24 08:26:19 EDT 2011
Jim,
Do you have a solution to this one either? The reference map must've been missed during testing.  I might have sometime this weekend to review the code.
Though, to be honest, I'd love to just deprecate that damn thing.  It barely work as implemented but I understand reference maps have a lot of "momentum."
>________________________________
>From: Eli Adam <EAdam at co.lincoln.or.us>
>To: James Auld <jauld at city.kawarthalakes.on.ca>; geomoose-users at lists.sourceforge.net
>Sent: Wednesday, May 25, 2011 12:57 PM
>Subject: Re: [Geomoose-users] reference map at 2.4 fails
>Sorry, I dropped the list in my reply.  Here it is for the list:
>Thanks for the advice - yes I did find that earlier thread and have
>tried all the changes suggested - nothing works.  It's just odd that the
>exact same config works perfectly at 2.2 yet fails at 2.4 - I haven't
>changed any of the other files at the update...
>___________________
>James Auld
>GIS Supervisor
>Information Technology
>City of Kawartha Lakes
>Phone: 705-324-9411 ext: 1385
>Toll Free: 1-888-822-2225
>Fax: 705-324-1750
>-----Original Message-----
>From: Eli Adam [mailto:EAdam at co.lincoln.or.us]
>Sent: May 25, 2011 1:19 PM
>To: James Auld
>Jim,
>Have you tried changed some of those numbers, like a much larger
>name="reference_map.maximum_ratio">20</param>?
>Have you checked this thread (which in turn mentions another thread)
>which had some similar issues?
>http://sourceforge.net/mailarchive/message.php?msg_id=27252751
>Eli
>>>> On 5/25/2011 at 9:30 AM, in message
><1E466BE4B6112646A7FB1E507BAE9F2917F1FC98 at COKLEXVS.city.kawarthalakes.on.ca>,
>"James Auld" <jauld at city.kawarthalakes.on.ca> wrote:
>> I've just updated to 2.4 and my reference map now acts as a magnifying
>> map rather than a reference map (it still works perfectly fine in 2.2)
>> - I have not changed any of the config settings - they are listed below:
>> ]]></param>
>>          <param name="fractional_zoom">true</param>
>>         <param name="ground_units">m</param>
>>         <param
>> name="scales">.05,.1,.5,1,4,8,16,24,32,64,128,270,550,1000</param>
>>         <param name="reference_map.enabled">true</param>
>>         <param name="reference_map.width ">200</param>
>>         <param name="reference_map.height">200</param>
>>                                <param
>>         <param name="reference_map.minimum_ratio">10</param>
>>         <param name="scale_line.bottom_units"></param>
>>         <param name="scale_line.top_units">km</param>
>>         <param name="coordinate_display.usng">False</param>
>>         <param name="jumpto_scales"><![CDATA[
>>             '1:50000' : 50000,
>>             '1:25000' : 25000,
>>             '1:10000' : 10000,
>>             '1:5000' : 5000,
>>             '1:1000' : 1000,
>>     ]]></param>
>> Any thoughts?
>> Jim
>> ___________________
>> James Auld
>> GIS Supervisor
>> Fax: 705-324-1750
>>  <<Picture (Device Independent Bitmap)>>
>vRanger cuts backup time in half-while increasing security.
>With the market-leading solution for virtual backup and recovery,
>you get blazing-fast, flexible, and affordable data protection.
>Download your free trial now.
>http://p.sf.net/sfu/quest-d2dcopy1
>_______________________________________________
>Geomoose-users mailing list
>Geomoose-users at lists.sourceforge.net
>https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110624/765d102c/attachment.html
More information about the Geomoose-users mailing list
