[Geomoose-users] WMS raster layer won't print
Mark Volz MarkVolz at co.lyon.mn.us
Fri Jun 24 12:43:49 EDT 2011
Jim,
For printing WMS layers in the same projection as your map, try updating print.php and print_util.php from http://geomoose.svn.sourceforge.net/viewvc/geomoose/moose2-trunk/htdocs/php/  I think I used a version around #425.
Mark Volz
GIS Specialist
Message: 3
Date: Fri, 24 Jun 2011 05:24:40 -0700 (PDT)
Subject: Re: [Geomoose-users] WMS raster layer won't print
To: Jim <jauld at city.kawarthalakes.on.ca>,
	"geomoose-users at lists.sourceforge.net"
	<geomoose-users at lists.sourceforge.net>
Message-ID:
	<1308918280.37469.YahooMailNeo at web161215.mail.bf1.yahoo.com>
Content-Type: text/plain; charset="iso-8859-1"
Hi Jim, did you get an answer to this question?
Do you have control over the WMS service? ?There is a chance that the print-request is asking for an image larger than the server will allow to be rendered.
>________________________________
>From: Jim <jauld at city.kawarthalakes.on.ca>
>To: geomoose-users at lists.sourceforge.net
>Sent: Wednesday, June 15, 2011 9:17 AM
>Subject: [Geomoose-users] WMS raster layer won't print
>I have a WMS layer coming from Geoserver as a base layer on my map - it is in
>the same projection as all the other layers.? When I go to print a map, the
>WMS layer (it's an aerial photo raster) doesn't show up, but all other
>layers do.? After checking a number of the other maps in the Geomoose
>gallery, I've found that about 75% of them have the same problem - base
>raster layers fail to show up when printing the map, so it's obviously a
>fairly widespread problem. Has anyone found out what causes this failure and
>how to fix it?
>View this message in context: http://geomoose-users.964460.n3.nabble.com/WMS-raster-layer-won-t-print-tp3067473p3067473.html
>Sent from the Geomoose-users mailing list archive at Nabble.com.
>EditLive Enterprise is the world's most technically advanced content
>authoring tool. Experience the power of Track Changes, Inline Image
>Editing and ensure content is compliant with Accessibility Checking.
>http://p.sf.net/sfu/ephox-dev2dev
>_______________________________________________
>Geomoose-users at lists.sourceforge.net
>https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
