[Geomoose-users] Migrating geomoose v1.6 Microsoft to Linux
geo3d
geomatrix3d at gmail.com
Thu Jun 30 08:22:07 EDT 2011
Hey folks, need an extra pair of eyes; I've gone over my configuration for a
few days now and can't seem to find a solution to my problem: ( my map has
been operational for nearly 2 years on a Windows box running xp and apache2)
Problem: select.php and print.php aren't being called - I'm fairly sure its
a simple syntax error but damned if I can find it.
My test map can be found @ maps.peachtree-city.org/Test
I've got everything else to include searching, identifying, etc up and
going.
I've attached a screen shot of Firebug response:
http://geomoose-users.964460.n3.nabble.com/file/n3125537/mapPHP.png
The following snippets apply to my map configuration:
XML
<service title="Select Feature" default="true" locked="true"
cursor="url(cursors/select.cur), auto" shape="box" type="inspect-search"
icon="shared/images/toolbar/draw_polygon.jpg"
highlight="shared/images/toolbar/draw_polygon_selected.jpg">
<url>php/select.php</url>
<input type="multipoint" name="coords"/>
<input type="hidden" name="shape" value="poly"/>
<input type="hidden" name="map"
value="/var/www/iMap/Test/maps_countydemo/select.map"/>
<input type="hidden" name="select"
<input type="select" name="layer" title="Layer to Select:">
<option value="Parcels:PARCEL_NO">Parcels</option>
</input>
<input type="hidden" name="output" value="html"/>
</service>
select.php
<?php
# select.php (c) 2007 Dan "Ducky" Little
# Write for the GeoMOOSE project, sponsored by the OpenMNND Organization
# PHP Translation of the Perl script select.pl
# Make the PHP Script Shut Up, but still give something useful if there
# is a legit error or parsing bug.
error_reporting(E_ERROR | E_PARSE);
# Include the GeoMOOSE PHP Library Utilities
include('Configuration.php');
include('geomoose_php_util.php');
# Get in the information from the request
$coordinates = $_REQUEST['coords'];
$title = $_REQUEST['title'];
$shapeType = $_REQUEST['shape'];
$buffer = $_REQUEST['buffer'];
$layer = $_REQUEST['layer'];
$output = $_REQUEST['output'];
$identifyMap = $_REQUEST['map'];
$selectMap = $_REQUEST['select'] ..........
Configuration.php
<?php
* This file controls the basic settings for the GeoMOOSE PHP Services
* Any of these settings can be over-ridden in the specific script.
$TEMP_DIRECTORY = '/var/www/tmp/';
$TEMP_WEB = '/tmp/';
# Do not forget the trailing "/"!
$PARENT_DIRECTORY = '/var/www/iMap/Test/maps_countydemo/';
# This is used as a template by the buffer selection script
$DRAWING_MAP = '/var/www/iMap/Test/php/resources/draw.map';
$DEFAULT_DELIM = ':';
$DEFAULT_OUTPUT = 'html'; # This should be the default, some scripts provide
XML, CSV, and PDF, but they all have HTML modes
# Printing Options
$PRINT_SHOW_IMAGE_LINK = false;
/*** Needed for PDF Printing... the location of FPDF ***/
$FPDF_LOCATION = '/fpdf/';
/*** Configuration for Mailing Labels ***/
$PARCELS_MAP = '/var/www/iMap/Test/maps_countydemo/select.map';
$PARCELS_LAYER = 'Parcels';..............................................
View this message in context: http://geomoose-users.964460.n3.nabble.com/Migrating-geomoose-v1-6-Microsoft-to-Linux-tp3125537p3125537.html
Sent from the Geomoose-users mailing list archive at Nabble.com.
More information about the Geomoose-users
