[Geomoose-users] Issue with running GeoMoose2 -IIS 6, computer that already has GeoMoose 1.6
Dan Little danlittle at yahoo.com
Tue Mar 22 09:22:46 EDT 2011
The problem is that they need to find php.ini and enable those modules or point
the PHP install to the right path.  PHP is working but dl() is probably confused
as to where those dlls reside.
IE configuration tends to be more finnicky than apache.  Maybe BrianF can chime
in as he runs (ran?) IIS.
>From: Mark Volz <MarkVolz at co.lyon.mn.us>
>To: geomoose-users at lists.sourceforge.net
>Sent: Mon, March 21, 2011 2:25:57 PM
>Subject: [Geomoose-users] Issue with running GeoMoose2   -IIS 6, computer that
>Hello,
>A college of mine is attempting to set up GeoMoose2on an IIS 6 server.  GeoMoose
>1.6 is already working on that server. When I looked at the site I noticed that
>the PHP extensions were not loaded properly.  I amsurprisedthat this is an issue
>since GeoMoose 1.6 is working fine.
>They have their GeoMoose 1 and 2 on the G:\ drive.  I wonder if that is part of
>the problem. Does anyone have any troubleshooting recommendations?
>Error:
>PHP Warning:  dl() [<a href='function.dl'>function.dl</a>]: Unable to load
>dynamic library './php_gd2.dll' - The specified module could not be found.
> in G:\MS4W\apps\geomoose2\htdocs\php\config.php on line 37
>dynamic library './php_curl.dll' - The specified module could not be found.
> in G:\MS4W\apps\geomoose2\htdocs\php\config.php on line 41
>dynamic library './php_mapscript.dll' - The specified module could not be found.
> in G:\MS4W\apps\geomoose2\htdocs\php\config.php on line 45
>dynamic library './php_dbase.dll' - The specified module could not be found.
> in G:\MS4W\apps\geomoose2\htdocs\php\config.php on line 49
>Thank You
>Mark Volz
>GIS Specialist
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110322/7a8121d7/attachment.html
More information about the Geomoose-users mailing list
