[Geomoose-users] Configure Identify and query
aborruso
aborruso at gmail.com
Sat Mar 26 18:17:50 EDT 2011
Hi Dan,
Dan Little wrote:
> Can you give a little more specifics? There are a few layers configured
> in the
> demo and I do see (now) that the docs are a bit abysmal.
I think that it should be a doc that explains the necessary steps to make
"queryable" a layer.
In example, "if you want to use identify tool, you must add to layer
metadata a row with 'identify_record' 'identify_layername.html'. To use
popup tool, you instead must create ..."
To reach this goal at the moment it's necessary to do a sort of reverse
engineering.
This is for me, I do not know if Bob agrees with me.
Once again, thank you,
a
View this message in context: http://geomoose-users.964460.n3.nabble.com/Geomoose-users-Configure-Identify-and-query-tp2725261p2737139.html
Sent from the Geomoose-users mailing list archive at Nabble.com.
More information about the Geomoose-users
