[Geomoose-users] Strange PHP error on Query
Stephen Knox
stephenknox73 at gmail.com
Tue May 3 21:38:24 EDT 2011
Incidentally, the same service doesn't appear to be working on the demo site
(http://www.geomoose.org/demo/geomoose2/geomoose.html#) (search Parcels
functionality). It appears the same thing is happening as in my application.
The debug output from mapserver seems to be getSymbol(): Symbol definition
error. Parsing error near (per_ttw_lu):(line 297).
On Tue, May 3, 2011 at 10:26 PM, Stephen Knox <stephenknox73 at gmail.com>wrote:
> Don't think that's it it's still not working. I think it is the queryByRect
> function itself.
> On Tue, May 3, 2011 at 8:27 PM, Dan Little <danlittle at yahoo.com> wrote:
>> Oh, Doh, yeah, MapServer cannot automatically pick up the extent of a
>> PostGIS layer. You need to specify it manually...
>> LAYER
>> ... stuff ...
>> EXTENT minx,miny,maxx,maxy
>> ... stuff ...
>> END
>> *From:* Stephen Knox <stephenknox73 at gmail.com>
>> *To:* Dan Little <danlittle at yahoo.com>
>> *Cc:* "geomoose-users at lists.sourceforge.net" <
>> geomoose-users at lists.sourceforge.net>
>> *Sent:* Tuesday, May 3, 2011 2:25 PM
>> *Subject:* Re: [Geomoose-users] Strange PHP error on Query
>> The data definitely maps OK. I can see it both in GeoMoose as a normal
>> layer and in Mapserver. I can also see the calculated field with Identify.
>> The problems just seems to be filtering/querying it.
>> I wondered whether it's something to do with my version - I am using
>> 2.4RC1 and I saw reference to bugs relating to certain functions in this
>> release on the mailing list. I am also using Mapserver 5.6.3 for Fedora 14.
>> The error seems to be coming in on the call to
>> $queryLayer->queryByRect($queryLayer->getExtent());
>> in query.php (around line 320)
>> It's nothing to do with the getExtent function, as I tried putting my own
>> values in there. I assume from the only related bug
>> <http://trac.osgeo.org/mapserver/ticket/3691>I could find that this the
>> error message indicates the layer can't be queried because it's already
>> open.
>> Does that help track this down at all?
>> Steve
>> On Tue, May 3, 2011 at 1:03 PM, Dan Little <danlittle at yahoo.com> wrote:
>> I think the querying it's doing is looking for metadata. Does this layer
>> map okay? The error you're seeing is essentially "Ack, I'm MapServer and I
>> can't figure out what the hell is going on with this layer!" Some easy
>> stuff to try:
>> 1) Ensure you can map the data.
>> 2) Convert your inner query into a view and make sure there is a valid
>> entry in geometry_columns for the view.
>> 3) Curse aloud to others.
>> 4) Repost to mailing list if none of the above works.
>> *To:* geomoose-users at lists.sourceforge.net
>> *Sent:* Monday, May 2, 2011 7:02 PM
>> Excuse my inexperience but I have another query about getting query
>> functionality to work in GeoMoose. It seems to be querying the database for
>> a few seconds, then I get no Valid Response and the following error in PHP:
>> httpd: mappostgis.c:1882: msPostGISLayerResultsGetShape: Assertion
>> `layer->layerinfo != ((void *)0)' failed.
>> I have the following section of mapbook:
>> <service name="search_oas">
>> <url>php/query.php</url>
>> <step type="input">
>> <input type="select" name="comparitor0" title="Percentage
>> Travel by UG 2001">
>> <option value="gt">Greater Than</option>
>> <option value="eq">Equal To</option>
>> <option value="lt">Less Than</option>
>> </input>
>> <input type="user" name="value0" title=""/>
>> <input type="hidden" name="highlight" value="true"/>
>> <input type="hidden" name="mode" value="search"/>
>> <input type="hidden" name="layer0" value="uglines/oas"/>
>> <input type="hidden" name="template0" value="itemquery"/>
>> <input type="hidden" name="zoom_to_first" value="false"/>
>> <input type="hidden" name="fieldname0" value="per_ttw_lu"/>
>> </step>
>> </service>
>> and the layer definition below:
>> LAYER
>> CONNECTIONTYPE postgis
>> NAME "oas"
>> CONNECTION "user=postgres password=postgres dbname=lustations
>> host=localhost"
>> DATA "the_geom from (SELECT gid, the_geom, census_code, ttw_by_lu,
>> (ttw_by_lu::REAL/tot_pop::REAL)*100 as per_ttw_lu, tot_pop FROM oa_data) as
>> foo using srid=27700 using unique gid"
>> STATUS ON
>> TYPE POLYGON
>> METADATA
>> identify_record "identify_oas.html"
>> itemquery "oa_itemquery.html"
>> END
>> CLASS
>> STYLE
>> OUTLINECOLOR 0 0 0
>> #COLOR 216 250 138
>> WIDTH 1
>> END
>> END
>> END
>> my oa_itemquery.html looks like this:
>> <!-- MapServer Template -->
>> <tr bgcolor="#DEE5EB"><td colspan="2"><b><u>Output Areas</u></b></tr>
>> <tr>
>> <td align="right"><b>Census Code:</b></td>
>> <td>[census_code]</td>
>> </tr>
>> <tr>
>> <td align="right"><b>Percentage travel by LU:</b></td>
>> <td>[per_ttw_lu]</td>
>> </tr>
>> <tr>
>> <td> </td>
>> <td> </td>
>> </tr>
>> WhatsUp Gold - Download Free Network Management Software
>> The most intuitive, comprehensive, and cost-effective network
>> management toolset available today. Delivers lowest initial
>> acquisition cost and overall TCO of any competing solution.
>> http://p.sf.net/sfu/whatsupgold-sd
>> Geomoose-users mailing list
>> Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110504/5fd41782/attachment.html
More information about the Geomoose-users
