[Geomoose-users] Loading on server
DEAN ANDERSON
ANDERSON.DEAN at co.polk.or.us
Fri May 13 11:04:05 EDT 2011
You may want to have your IT Folks check the permissions on the tmp
folder. Not sure if this will help but I want to remember that I had
something similar and that fixed it.
Dean
>>> "Jacob Rodel" 05/13/11 7:56 AM >>>
<!--/* Font Definitions */@font-face{font-family:"Cambria
Math";panose-1:2 4 5 3 5 4 6 3 2
4;}@font-face{font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2
4;}@font-face{font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2
4;}@font-face{font-family:"Bookman Old Style";panose-1:2 5 6 4 5 5 5 2 2
4;}@font-face{font-family:"Comic Sans MS";panose-1:3 15 7 2 3 3 2 2 2
4;}/* Style Definitions */p.MsoNormal, li.MsoNormal,
div.MsoNormal{margin:0in;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri","sans-serif";mso-believe-normal-left:yes;}a:link,
span.MsoHyperlink{mso-style-priority:99;color:blue;text-decoration:underline;}a:visited,
span.MsoHyperlinkFollowed{mso-style-priority:99;color:purple;text-decoration:underline;}p{mso-style-priority:99;mso-margin-top-alt:auto;margin-right:0in;mso-margin-bottom-alt:auto;margin-left:0in;font-size:12.0pt;font-family:"Times
New
Roman","serif";}span.emailstyle17{mso-style-name:emailstyle17;font-family:"Calibri","sans-serif";color:black;}span.EmailStyle19{mso-style-type:personal-reply;font-family:"Calibri","sans-serif";color:black;}.MsoChpDefault{mso-style-type:export-only;font-size:10.0pt;}@page
WordSection1{size:8.5in 11.0in;margin:1.0in 1.0in 1.0in
1.0in;}div.WordSection1{page:WordSection1;}-->p.MsoNormal{margin-left:3.0pt;}When
I hit print It will actually will put files in the tmp folder on the
server but they have a file size of zero. I then receive this error:
Fatal error: Maximum execution time of 30 seconds exceeded in
E:\ms4w\apps\toddcounty\htdocs\php\print_util.php on line 52
If I turn off most of the layers I do not receive an error but don’t get
the download option. The information tab is just blank. Is there a way
I can troubleshoot this somehow?
Jake Rodel
GIS Technician
Todd County GIS & Land Services Dept.
347 Central Ave Suite 1
Long Prairie, MN 56347
(320) 732-4248
From: Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
Sent: Friday, May 13, 2011 9:31 AM
To: Jacob Rodel; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Loading on server
Jake,
It sounds like you have a relative link that should be an explicit link
or vice-versa for those services.
Is the TMP location identified explicitly on your machine vs the remote
server it's being installed on? I believe the results for the search
and possibly the PDF output are placed in a temp location for display,
and this location may be different between machines. Of defaults to a
different location.
bobb
>>> "Jacob Rodel" wrote:
I am having a couple weird issues trying to setup our application on the
server and was just wondering if anybody had any insight as to what I
might be overlooking. When I run on my hard drive everything works fine
but when our IT loads it on the server the print service doesn’t return
the option to download the pdf. Also when you search for taxpayers it
selects and highlight the parcels but does not display the results in
the information tab. All that you get is the header.
Jake Rodel
GIS Technician
(320) 732-4248
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110513/f418e4bd/attachment.html
More information about the Geomoose-users
