[Geomoose-users] reference map at 2.4 fails
Eli Adam
EAdam at co.lincoln.or.us
Wed May 25 13:57:58 EDT 2011
Sorry, I dropped the list in my reply. Here it is for the list:
Thanks for the advice - yes I did find that earlier thread and have
tried all the changes suggested - nothing works. It's just odd that the
exact same config works perfectly at 2.2 yet fails at 2.4 - I haven't
changed any of the other files at the update...
___________________
James Auld
GIS Supervisor
Information Technology
City of Kawartha Lakes
Phone: 705-324-9411 ext: 1385
Toll Free: 1-888-822-2225
Fax: 705-324-1750
-----Original Message-----
Sent: May 25, 2011 1:19 PM
To: James Auld
Subject: Re: [Geomoose-users] reference map at 2.4 fails
Jim,
Have you tried changed some of those numbers, like a much larger
name="reference_map.maximum_ratio">20</param>?
Have you checked this thread (which in turn mentions another thread)
which had some similar issues?
http://sourceforge.net/mailarchive/message.php?msg_id=27252751
Eli
>>> On 5/25/2011 at 9:30 AM, in message
<1E466BE4B6112646A7FB1E507BAE9F2917F1FC98 at COKLEXVS.city.kawarthalakes.on.ca>,
"James Auld" <jauld at city.kawarthalakes.on.ca> wrote:
> I've just updated to 2.4 and my reference map now acts as a magnifying
> map rather than a reference map (it still works perfectly fine in 2.2)
> - I have not changed any of the config settings - they are listed below:
> ]]></param>
> <param name="fractional_zoom">true</param>
> <param name="ground_units">m</param>
> <param
> name="scales">.05,.1,.5,1,4,8,16,24,32,64,128,270,550,1000</param>
> <param name="reference_map.enabled">true</param>
> <param name="reference_map.width ">200</param>
> <param name="reference_map.height">200</param>
> <param
> <param name="reference_map.minimum_ratio">10</param>
> <param name="scale_line.bottom_units"></param>
> <param name="scale_line.top_units">km</param>
> <param name="coordinate_display.usng">False</param>
> <param name="jumpto_scales"><![CDATA[
> '1:50000' : 50000,
> '1:25000' : 25000,
> '1:10000' : 10000,
> '1:5000' : 5000,
> '1:1000' : 1000,
> ]]></param>
> Any thoughts?
> Jim
> ___________________
> James Auld
> GIS Supervisor
> Fax: 705-324-1750
> <<Picture (Device Independent Bitmap)>>
More information about the Geomoose-users
