[Geomoose-users] Trouble entering variable in custom.js
Brent Fraser bfraser at geoanalytic.com
Tue Nov 8 10:44:14 EST 2011
Bob,
   I'm not clear on what you're trying to do.  You want to pass a
variable to a function (showParcelDataTable) in custom.js, executed when
a button is clicked where?
Best Regards,
Brent Fraser
On 11/4/2011 3:44 PM, Bistrais, Bob wrote:
> This is one of those things that should be trivial, but I'm having
> trouble figuring it out.  I want to add some code to the results table
> view in GM.  When the user clicks the Close Table button, I want to
> execute a bit of custom code.  I need to pass a variable to that
> line.  Sounds simple enough, and the variable is defined in the
> showParcelDataTable function of custom.js.  But the variable is not
> getting through to the line of code I want it in.
> It's an extremely long line of code, so I won't paste it all here, but
> the line starts as this:
> $(".resultGlobalTools").html("<img src='images/toolbar/zoomin.png' ...
> So I seem to have trouble passing the variable.  Any suggestions?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111108/3066d6e4/attachment.html
More information about the Geomoose-users mailing list
