[Geomoose-users] Change Latitude and Longitude format
Ed Boesenberg eboesenberg at niraengineers.com
Tue Nov 8 13:14:00 EST 2011
Here is my hack.  The code below was inserted into the displayCoordinates
function somewhere near line 1909.
lat_d = degrees.y;
lat_m = (lat_d - Math.floor(lat_d)) * 60;
lat_s = (lat_m - Math.floor(lat_m)) * 60;
lon_d = Math.abs(degrees.x);
lon_m = (lon_d - Math.floor(lon_d)) * 60;
lon_s = (lon_m - Math.floor(lon_m)) * 60;
The code below was inserted somewhere near line 1926:
html += Math.round(lat_d) + "\u00B0" + '  ' + Math.round(lat_m) + "'" + '  '
+ lat_s.toFixed(4) + "''" + ', ' + Math.round(lon_d) + "\u00B0" + '  ' +
Math.round(lon_m) + "''" + '  ' + lon_s.toFixed(4) + "''";
Johan,
Did you have something similar?
Ed
From: Johan Forsman [mailto:Johan.Forsman at LA.GOV]
Sent: Tuesday, November 08, 2011 12:36 PM
To: Brent Fraser; Ed Boesenberg
Cc: geomoose-users at lists.osgeo.org
Subject: RE: [Geomoose-users] Change Latitude and Longitude format
Ed/Brent:
Some time back I had a similar need to have simultaneous display of DMS and
DD with fixed decimal places. My OpenLayers was 2.8 at the time (it still
is), but I discovered that version 2.10 supposedly had an in-built
"getFormattedlonlat" function that could do what I needed. I shamelessly
adapted that function from the OpenLayers source and inserted it with
several modification into compiled.js and it worked fine. The attached
screenshot shows how it looks.
You may be able to directly use the function if you have a more current
OpenLayers version than I do, otherwise I can share my extraordinarily
inelegant hack.
Take care,
Johan.
[mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Brent Fraser
Sent: Tuesday, November 08, 2011 9:58 AM
To: Ed Boesenberg
Subject: Re: [Geomoose-users] Change Latitude and Longitude format
Ed,
  Have a look at the displayCoordinates function in main.js.
Once we get  our issue tracker running, I'll add this as a requested
feature.  In the mean time you may need to hack the function yourself.
Best Regards,
Brent Fraser
On 11/4/2011 7:49 AM, Ed Boesenberg wrote:
I would like to format the latitude and longitude output at the bottom of
the map to DD MM SS.SSS.  The current format is DD.DDD.  What function do I
need to modify?
Thanks,
Ed Boesenberg
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111108/8e8f9184/attachment.html
More information about the Geomoose-users mailing list
