[Geomoose-users] Link URL for GeoMoose
    Atif Butt
    matifbutt at gmail.com
    Tue Nov  8 18:54:01 EST 2011
Hi All
I have tried the same steps (1-5) inside the GeoMOOSE-2.4-MS4W version. And
bookmark start working, but its not working inside the
GeoMOOSE-mercdemo-2.2-MS4W version.
Secondly, if i installed the  *GeoMOOSE-mercdemo-2.4-MS4W version*
its not showing up any base map as base layer, just empty layer without any
tools showed.
Can you help me.
Regards
Atif
On Tue, Nov 8, 2011 at 6:07 PM, Atif Butt <matifbutt at gmail.com> wrote:
> Hi All
> I havent found any documentation for how to implement this
> geoMOOSE.bookmark feature. Could you please help me, if there is any
> resources (you know) for adding this bookmark feature;
> Steps I did sofar using GeoMOOSE-mercdemo-2.2-MS4W :
> 1) I have added the menu name Bookmark shows under drawing tools
> 2) coppied the BookmarkToTab,js file inside the htdocs -> extenstions
> folder
> 3) enabled this extension inside geomoose.html file
> 4) enabled the tool defination inside mapbook_webmercator.xml file as
> follow
> <tool name="bookmark" title="Bookmark this Session" type="javascript"
> selectable="false">
> GeoMOOSE.bookmark();
> </tool>
> 5) copied the bookmark.js file inside the htdocs -> geomoose folder
> After this configuration I havent got any +ve result except menu
> "bookmark" showing inside the drawing menu.
> Regards
> Atif
> On Tue, Nov 8, 2011 at 6:00 PM, Atif Butt <matifbutt at gmail.com> wrote:
>> Hi All
>> folder
>> follow
>> selectable="false"> GeoMOOSE.bookmark(); </tool>
>> Regards
>> Atif
>> On Tue, Nov 8, 2011 at 11:27 AM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>>>  http://www.osgeo.org/pipermail/geomoose-users/2011-January/002855.html
>>> Best Regards,
>>> Brent Fraser
>>> On 11/8/2011 9:14 AM, Atif Butt wrote:
>>>  Hi All
>>> resources (you know) for adding this bookmark feature to the menu.
>>> Regards
>>>   On Mon, Nov 7, 2011 at 4:57 PM, Atif Butt <matifbutt at gmail.com> wrote:
>>>> Hi Dan,
>>>> Have you come across or used this function (GeoMOOSE.bookmark) by
>>>> chance.
>>>> and Secondly, I think in Geomosse Version 2.2 is not using this
>>>> function in its demo.
>>>> Do you have any suggestion from where I need to start digging this (
>>>> GeoMOOSE.bookmark) API function.
>>>> Thanks
>>>> Regards
>>>> Atif
>>>> On Mon, Nov 7, 2011 at 2:42 PM, Atif Butt <matifbutt at gmail.com> wrote:
>>>>> Thanks let me have a look.
>>>>> On Mon, Nov 7, 2011 at 1:42 PM, Dan Little <danlittle at yahoo.com>wrote:
>>>>>>  Yes, there is.  You might want to look at the GeoMOOSE.bookmark API
>>>>>> function.
>>>>>> *From:* Atif Butt <matifbutt at gmail.com>
>>>>>> *To:* "geomoose-users at lists.osgeo.org" <
>>>>>> geomoose-users at lists.osgeo.org>
>>>>>> *Sent:* Saturday, November 5, 2011 3:58 PM
>>>>>> *Subject:* [Geomoose-users] Link URL for GeoMoose
>>>>>>   Hi
>>>>>>  Is there any way if I want to make a URL button or Link, send and
>>>>>> print Buttons (like http://maps.google.com on the top right corner).
>>>>>> Regards
>>>>>> Muhd
>>>>>>  _______________________________________________
>>>>>> Geomoose-users mailing list
>>>>>> Geomoose-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111108/698fc730/attachment.html
More information about the Geomoose-users
