[Geomoose-users] Problem adding a link to the identify results
Brent Fraser bfraser at geoanalytic.com
Wed Nov 9 17:28:42 EST 2011
Yikes!    I prefer the IBM 2540 Card Punch.
Best Regards,
Brent Fraser
On 11/9/2011 3:16 PM, Bob Basques wrote:
> Vim is great for everything here, but has a steep learning curve.
>  I've been using VI/VIM for years though.
> bobb
> >>> Brent Fraser <bfraser at geoanalytic.com> wrote:
> I keep a copy of UltraEdit around for its awesome Column Mode
> Best Regards,
> Brent Fraser
> On 11/9/2011 2:47 PM, Bob Basques wrote:
>> Ultraedit is another good editor, most of the same features, also
>> lets you keep editing projects organized and allows for batch editing
>> and replace across many files.
>> bobb
>> Some document editors (e.g. Word) "help" you by changing text.  I
>> like using Notepad++ to keep it simple.  It colorizes the text so I
>> can tell if things are commented out or quoted, and it highlights
>> open/closing tags in html and xml.
>> Best Regards,
>> Brent Fraser
>> On 11/9/2011 2:33 PM, Ed Boesenberg, III wrote:
>>> Thanks, that worked.  I don't know how the back-double-quotes even
>>> got there, I don't know how to type them in either.
>>> *From:* Brent Fraser [mailto:bfraser at geoanalytic.com]
>>> *Sent:* Wednesday, November 09, 2011 4:13 PM
>>> *To:* Ed Boesenberg, III
>>> *Cc:* 'Ed Boesenberg'; geomoose-users at lists.osgeo.org
>>> *Subject:* Re: [Geomoose-users] Problem adding a link to the
>>> identify results
>>> Ed,
>>>   IE is not very forgiving with HTML that deviates from the spec.  I
>>> changed the back-double-quote (”) to a forward?-double-quote (") and
>>> it rendered properly.
>>> Best Regards,
>>> Brent Fraser
>>> On 11/9/2011 1:21 PM, Ed Boesenberg, III wrote:
>>> I mean that no text is being rendered.  It is being rendered if I DO
>>> NOT place my code, as shown in the previous email, into the identify
>>> html.
>>> It worked in GM 2.0 but not the current GM 2.4 version.
>>> *From:*geomoose-users-bounces at lists.osgeo.org
>>> <mailto:geomoose-users-bounces at lists.osgeo.org> [mailto:geomoose-users-bounces at lists.osgeo.org]
>>> *On Behalf Of *Brent Fraser
>>> *Sent:* Wednesday, November 09, 2011 1:05 PM
>>> *To:* Ed Boesenberg
>>> *Cc:* geomoose-users at lists.osgeo.org
>>> <mailto:geomoose-users at lists.osgeo.org>
>>> identify results
>>> If you mean the PIN is not being substituted, it needs to be
>>> lowercase for a database column name but uppercase for a shapefile
>>> field (a Mapserver thing).  If you mean no text at all is being
>>> rendered, likely mapserver can't find indentify.html ?
>>> Best Regards,
>>> Brent Fraser
>>> On 11/9/2011 10:53 AM, Ed Boesenberg wrote:
>>> Why do results not show up in the Information tab if the code below
>>> is added to an identify html file or popup html file?
>>> <tr>
>>> <td> <a
>>> href="http://www2.county.allegheny.pa.us/RealEstate/GeneralInfo.aspx?ParcelID=[PIN]"
>>> <http://www2.county.allegheny.pa.us/RealEstate/GeneralInfo.aspx?ParcelID=%5bPIN%5d> target=”_blank”>See
>>> Owner Info on Allegheny County Website</a></td>
>>> </tr>
>>> Thanks,
>>> Ed Boesenberg
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111109/debdb32d/attachment-0001.html
More information about the Geomoose-users mailing list
