[Geomoose-users] query.php and pgdb
Eli Adam
eadam at co.lincoln.or.us
Tue Nov 15 11:15:55 EST 2011
Michael,
I'm not sure about pgeo but to query PostGIS with MapServer you
need to specify "using unique". You can check out PostGIS details
here, http://www.mapserver.org/input/vector/postgis.html#data-access-connection-method
You can also ogrinfo the datasource to see which fields are being recognized.
HTH, Eli
On Tue, Nov 15, 2011 at 6:57 AM, Brent Fraser <bfraser at geoanalytic.com> wrote:
> Michael,
> It sounds like Mapserver (or OGR?) can't find the SYSTEM_ID field. How
> are you specifying which table in the database to use (what's your DATA
> object in the mapfile look like?
> Best Regards,
> Brent Fraser
> On 11/15/2011 6:32 AM, Reynolds, Michael J. (DOT) wrote:
> I’m having trouble with the Geomoose 2.4 query.php, ms4w 3.0.3 (mapserver
> 6.0.1) and a personal geodatabase (pgdb ms access mdb esri).
> I think I have it narrowed down to an issue with the setFilter or the
> $filter_string.
> If I comment out $queryLayer->setFilter($filter_string); at about line 300
> then the Search By runs and returns ALL features using the template. Proves
> template is good, map file is good, connection is possible to the data
> (mapserver ogr mapscript pgdb working together ok).
> My map file is very simple for testing purposes:
> CONNECTIONTYPE OGR
> CONNECTION 'mte_systems.mdb'
> DATA "SIGNAL_SYSTEMS"
> No class items or expressions.
> The filter query.php builds is $filter_string = upper(SYSTEM_ID) like
> '%'||upper('27')||'%'
> The field SYSTEM_ID is all capital in the database (matters?). The
> SYSTEM_ID field is a number data type.
> MS debug is active and reports the following when the setFilter line is
> active:
> [Tue Nov 15 07:25:17 2011].25000 getSymbol(): Symbol definition error.
> Parsing error near (upper):(line 228)
> [Tue Nov 15 07:25:17 2011].695000 msEvalExpression(): General error message.
> Cannot evaluate expression, no item index defined.
> … repeat above line equal number of times to the number of all features in
> the feature class …
> [Tue Nov 15 07:25:17 2011].788000 msQueryByRect(): Search returned no
> results. No matching record(s) found.
> [Tue Nov 15 07:25:18 2011].116000 msFreeMap(): freeing map at 036B6A18.
> Not sure what Item Index might be referring too. The PGDB has an OBJECTID
> field.
> Any suggestions on what to fiddle with next?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
