[Geomoose-users] geomoose on 64 bit
Brent Fraser bfraser at geoanalytic.com
Thu Nov 17 17:16:43 EST 2011
If you get just the green banner without the button bar, that usually
means mapbook.xml file has not been sent to the client, and the most
likely candidate is a problem with PHP. since the mapbook is sent via
getmapbook.php.   If you want to check this, have a look at
http://www.geomoose.org/howto/getmapbook.html, or simply try
http://localhost/phpinfo.php
Best Regards,
Brent Fraser
On 11/17/2011 2:36 PM, Jim Hagedorn wrote:
> The error logs didn't tell me anything.  As for as I could read as
> soon as the green page came up without the map, it thought it was
> working and hence no errors.  I am using the plain geomoose.  I keep
> deleting the ms4w directory and uninstall apache every time I reload a
> different version.  I would just like to know why 2.4 doesn't seem to
> work with windows 7.  The 2.2 works just fine.
> If ducky is listening, what do you think?
> Thanks
> jim
> *From:*Ed Boesenberg [mailto:eboesenberg at niraengineers.com]
> *Sent:* Thursday, November 17, 2011 3:31 PM
> *To:* Jim Hagedorn; geomoose-users at lists.osgeo.org
> *Subject:* RE: [Geomoose-users] geomoose on 64 bit
> Did the error logs tell you anything?  Are you using the Web Mercator
> Demo or plain GeoMoose?
> You can have two versions of GeoMoose running, let me know if you
> would like instructions.
> *From:*Jim Hagedorn [mailto:jhagedorn at bannerassociates.com]
> *Sent:* Thursday, November 17, 2011 4:11 PM
> *To:* Ed Boesenberg; geomoose-users at lists.osgeo.org
> <mailto:geomoose-users at lists.osgeo.org>
> Ok I finally got it to work on windows 7.  I had to go back to
> geomoose 2.2 and ms4w 2.3.1 to finally get it all working.  So any
> idea why geomoose 2.4 wouldn't work with windows 7?
> Thanks
> jim
> *Sent:* Thursday, November 17, 2011 12:10 PM
> I have GeoMoose 2.4 and MS4W 3.0.1 running on Windows 7 64bit.  I
> didn't have to do anything special to get it up and running besides
> unzipping the GeoMoose and MS4W files and installing Apache using the
> batch file.  To check and see if MapServer is running, open your web
> browser and type 127.0.0.1 in the address and you should see something
> similar to the attached image file.
> Ed Boesenberg
> *From:*geomoose-users-bounces at lists.osgeo.org
> <mailto:geomoose-users-bounces at lists.osgeo.org>
> [mailto:geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Jim
> Hagedorn
> *Sent:* Thursday, November 17, 2011 12:38 PM
> *To:* geomoose-users at lists.osgeo.org
> *Subject:* [Geomoose-users] geomoose on 64 bit
> I have a client that got a new computer and I need to reinstall
> geomoose.  Have spent 2 hours trying to get it running.  Have
> installed it twice.  I can get the Apache server to work and the web
> page comes up but there is no map.  How do I check to see if mapserver
> is working?  That what seems to me to be the issue.  It is windows 7
> with 64 bit.
> Thanks
> jim
> Jim Hagedorn
> GIS Specialist
> Banner-Logo
> Banner Associates, Inc.
> 409 22nd Ave So | PO Box 298
> Brookings, South Dakota 57006
> Tel | 605.692.6342  Fax | 605.692.5714
> www.bannerassociates.com <http://www.bannerassociates.com/>
> *Confidentiality Notice:*This E-Mail (including attachments) is
> covered by the Electronic Communications Privacy Act, 18 U.S.C. &
> 2510-2524, is
> confidential and may be legally privileged. If you are not the
> intended recipient, you are hereby notified that any retention,
> dissemination, or copying
> of this communication is strictly prohibited. Please reply to the
> sender that you have received the message in error, and permanently
> delete the
> original and destroy any copy, including written (printed) copies of
> this email and any attachments thereto. Thank You.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
Skipped content of type multipart/related
More information about the Geomoose-users mailing list
