[Geomoose-users] geomoose on 64 bit
Brent Fraser
bfraser at geoanalytic.com
Mon Nov 21 11:05:15 EST 2011
Jim,
Same problem: on main.js's line 501, there's a trailing comma (delete
it).
Best Regards,
Brent Fraser
On 11/18/2011 9:25 AM, Jim Hagedorn wrote:
> Brent
> The demo started working but the clients page still isn't showing the
> map. The clients page is a php page because we are going to use a
> login screen.
> So this is the errors on the egan.php page
> SCRIPT1028: Expected identifier, string or number
> main.js, line 502 character 5
> SCRIPT5007: The value of the property 'main' is null or undefined, not
> a Function object
> egan.php, line 66 character 1
> Thanks
> jim
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Friday, November 18, 2011 9:55 AM
> *To:* Jim Hagedorn
> *Cc:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] geomoose on 64 bit
> Jim,
> From an old email
> (http://www.osgeo.org/pipermail/geomoose-users/2011-June/003117.html) :
> For GeoMOOSE, I had to remove the trailing comma on line 2216 of
> compiled.js to get:
> resolutions: CONFIGURATION.scales
> Best Regards,
> Brent Fraser
> On 11/18/2011 8:50 AM, Jim Hagedorn wrote:
> Brent
> This is the error messages
> compiled.js, line 2217 character 5
> a Function object
> geomoose.html, line 72 character 1
> jim
> *Sent:* Friday, November 18, 2011 9:46 AM
> *To:* Jim Hagedorn
> <mailto:geomoose-users at lists.osgeo.org>
> Jim,
> IE is very picky about parsing HTML. It has a debugger (F12).
> Best Regards,
> Brent Fraser
> On 11/18/2011 8:43 AM, Jim Hagedorn wrote:
> Brent
> When I bring up firefox to use the debugger, the map comes up. So
> it's something to do with IE. I'm going to reinstall 2.2 on the
> clients machine and be done with it until I can get this figured out.
> Thanks
> jim
> *Sent:* Friday, November 18, 2011 9:33 AM
> *To:* Jim Hagedorn
> Jim,
> What does your browser debugger report for the getmapbook.php request?
> Best Regards,
> Brent Fraser
> On 11/18/2011 7:35 AM, Jim Hagedorn wrote:
> Brent
> Reloaded the geomoose 2.4 and ms4w 2.3.1 and went to the phpinfo.php
> and it came right up. I still only get the green on the demo. With
> 2.2 I atleast got the map to come up.
> Thanks
> jim
> *Sent:* Thursday, November 17, 2011 4:17 PM
> *To:* Jim Hagedorn
> *Cc:* Ed Boesenberg; geomoose-users at lists.osgeo.org
> If you get just the green banner without the button bar, that usually
> means mapbook.xml file has not been sent to the client, and the most
> likely candidate is a problem with PHP. since the mapbook is sent via
> getmapbook.php. If you want to check this, have a look at
> http://www.geomoose.org/howto/getmapbook.html, or simply try
> http://localhost/phpinfo.php
> Best Regards,
> Brent Fraser
> On 11/17/2011 2:36 PM, Jim Hagedorn wrote:
> The error logs didn't tell me anything. As for as I could read as
> soon as the green page came up without the map, it thought it was
> working and hence no errors. I am using the plain geomoose. I keep
> deleting the ms4w directory and uninstall apache every time I reload a
> different version. I would just like to know why 2.4 doesn't seem to
> work with windows 7. The 2.2 works just fine.
> If ducky is listening, what do you think?
> Thanks
> jim
> *From:*Ed Boesenberg [mailto:eboesenberg at niraengineers.com]
> *Sent:* Thursday, November 17, 2011 3:31 PM
> *To:* Jim Hagedorn; geomoose-users at lists.osgeo.org
> *Subject:* RE: [Geomoose-users] geomoose on 64 bit
> Did the error logs tell you anything? Are you using the Web Mercator
> Demo or plain GeoMoose?
> You can have two versions of GeoMoose running, let me know if you
> would like instructions.
> *From:*Jim Hagedorn [mailto:jhagedorn at bannerassociates.com]
> *Sent:* Thursday, November 17, 2011 4:11 PM
> *To:* Ed Boesenberg; geomoose-users at lists.osgeo.org
> Ok I finally got it to work on windows 7. I had to go back to
> geomoose 2.2 and ms4w 2.3.1 to finally get it all working. So any
> idea why geomoose 2.4 wouldn't work with windows 7?
> Thanks
> jim
> *Sent:* Thursday, November 17, 2011 12:10 PM
> I have GeoMoose 2.4 and MS4W 3.0.1 running on Windows 7 64bit. I
> didn't have to do anything special to get it up and running besides
> unzipping the GeoMoose and MS4W files and installing Apache using the
> batch file. To check and see if MapServer is running, open your web
> browser and type 127.0.0.1 in the address and you should see something
> similar to the attached image file.
> Ed Boesenberg
> *From:*geomoose-users-bounces at lists.osgeo.org
> <mailto:geomoose-users-bounces at lists.osgeo.org>
> [mailto:geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Jim
> Hagedorn
> *Sent:* Thursday, November 17, 2011 12:38 PM
> *To:* geomoose-users at lists.osgeo.org
> *Subject:* [Geomoose-users] geomoose on 64 bit
> I have a client that got a new computer and I need to reinstall
> geomoose. Have spent 2 hours trying to get it running. Have
> installed it twice. I can get the Apache server to work and the web
> page comes up but there is no map. How do I check to see if mapserver
> is working? That what seems to me to be the issue. It is windows 7
> with 64 bit.
> Thanks
> jim
> Jim Hagedorn
> GIS Specialist
> Banner-Logo
> Banner Associates, Inc.
> 409 22nd Ave So | PO Box 298
> Brookings, South Dakota 57006
> Tel | 605.692.6342 Fax | 605.692.5714
> www.bannerassociates.com <http://www.bannerassociates.com/>
> *Confidentiality Notice:*This E-Mail (including attachments) is
> covered by the Electronic Communications Privacy Act, 18 U.S.C. &
> 2510-2524, is
> confidential and may be legally privileged. If you are not the
> intended recipient, you are hereby notified that any retention,
> dissemination, or copying
> of this communication is strictly prohibited. Please reply to the
> sender that you have received the message in error, and permanently
> delete the
> original and destroy any copy, including written (printed) copies of
> this email and any attachments thereto. Thank You.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
Skipped content of type multipart/related
More information about the Geomoose-users
