[Geomoose-users] Printing wms layers
Brent Fraser bfraser at geoanalytic.com
Wed Nov 23 11:33:23 EST 2011
Bob,
   I did  a fix some time ago (http://geomoose.org/trac/ticket/108)
regarding using the alpha channel in Print_util.php.  This fix is in
GeoMoose v2.4 so I'm confused...
Best Regards,
Brent Fraser
On 11/23/2011 9:27 AM, Bistrais, Bob wrote:
> It sure looks like a problem with the alpha channels.  Doesn't seem to
> matter which browser I use, either.
> *From:*Jim Klassen [mailto:klassen.js at gmail.com]
> *Sent:* Wednesday, November 23, 2011 10:43 AM
> *To:* Bistrais, Bob
> *Cc:* Bob Basques; <geomoose-users at lists.osgeo.org>
> *Subject:* Re: [Geomoose-users] Printing wms layers
> If the quality is different between PNG and GIF you are probably using
> PNG24 (as PNG8 and GIF should be identical image wise).
> My guess is a GD bug dealing with PNG24.  I'm not sure what your
> options are, but it sounds like the print.php needs to be rewritten
> with a more modern library.
> On Nov 23, 2011, at 9:11, "Bistrais, Bob" <Bob.Bistrais at maine.gov
> <mailto:Bob.Bistrais at maine.gov>> wrote:
>> Looks like I'm using png.
>> One thing I tried was to use gif in the mapbook.xml, for those WMS
>> layers, but while they displayed alright, the quality was awful.
>> *From:*Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
>> *Sent:* Wednesday, November 23, 2011 10:05 AM
>> *To:* geomoose-users at lists.osgeo.org
>> <mailto:geomoose-users at lists.osgeo.org>; Bistrais, Bob
>> *Subject:* RE: [Geomoose-users] Printing wms layers
>> What version of PNG, PNG8 PNG24, etc.
>> bobb
>> Yes, the WMS is outputting PNG.  What would be recommended instead?
>> *From:* Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
>> *Sent:* Tuesday, November 22, 2011 4:54 PM
>> Something to look at . . .
>> What is the format of the images from the WMS service?
>> PNG24 vs other PNG formats have caused problem in cross browser
>> situations.  Some versions of IE don't like one or the other for example.
>> bobb
>> I had brought up this question before but it seems to be happening
>> again.  I have a few layers that I consume in GeoMoose by WMS.  Some
>> of these are vecot line layers such as roads.  They work perfectly in
>> GeoMoose map view.  But when I compose a printable map, these layers
>> have a black background which obscures other layers and just plain
>> looks ugly.  If I set the "transparent"  property to false, the black
>> background goes away, but then I can't see any underlying data.
>> By the way, I do have control over the WMS services in this case.  I
>> tried to set Offsite to 0 0 0, but that didn't seem to help either.
>> The WMS is at MapServer 6.0.1.  Any suggestions?
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111123/da84fcc0/attachment-0001.html
More information about the Geomoose-users mailing list
