[Geomoose-users] feature editing - able to add polygons,
not able to delete or edit.
Dan Little
danlittle at yahoo.com
Tue Nov 29 15:54:03 EST 2011
Ah, this is actually kinda an easy one. There is a projections conflict for MapServer.
I'd try editing your mapfile and changing:
DATA 'wkb_geometry from (select polygon_id, title, owner, astext(wkb_geometry) as wkt_geometry, wkb_geometry from test_polygons) as mytable using unique polygon_id'
To:
DATA 'wkb_geometry from (select polygon_id, title, owner, astext(wkb_geometry) as wkt_geometry, wkb_geometry from test_polygons) as mytable using unique polygon_id using srid=-1'
I might be a little off on the syntax.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111129/71ab9953/attachment.html
More information about the Geomoose-users
