[Geomoose-users] Printing wms layers
Bistrais, Bob Bob.Bistrais at maine.gov
Tue Nov 29 16:34:48 EST 2011
Yeah, it's driving me up the wall.  I've made sure to set an imagecolor
and transparent on, on the WMS server.  But something's getting lost on
the print side, since the image looks normal on the app.
[mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Dan Little
Sent: Tuesday, November 29, 2011 2:51 PM
To: Bistrais, Bob; TC Haddad; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Printing wms layers
The composite print image is a JPEG but the request coming in should be
a JPG.  If you've got no background fill it *might* be filling black
instead of white but I'd bet there is still an alpha problem.
	To: Dan Little <danlittle at yahoo.com>; TC Haddad
<tchaddad at gmail.com>; geomoose-users at lists.osgeo.org
	Sent: Tuesday, November 29, 2011 1:50 PM
	Subject: RE: [Geomoose-users] Printing wms layers
	OK, I uppercased that, still getting the black alpha channel.
But here's something interesting.  Looking at the response URL:
http://localhost/broadband/php/download.php?id=print_13225959874924&ext=
jpg
	-Notice that the URL ends with ext=jpg.  So it looks like I'm
getting a jpeg even though I think I'm asking for png.
	Sent: Tuesday, November 29, 2011 2:40 PM
	You may need to have "format" all-capsed "FORMAT".  This is a
OpenLayers thing...
		Sent: Tuesday, November 29, 2011 1:36 PM
		Hi Tanya, Dan, and everyone,
		In mapbook.xml, I do have the format param set to
image/png, for those WMS layers which I want to have the Alpha channels
in.  That's in the parameters, but the URL itself is just the path to
the server, such as this:
		      <map-source name="base-vector" type="wms"
tiled="false" projection='EPSG:26919'>
<url>http://mapservertest.maine.gov/wms/mapserv.exe</url>
		                        <layer name="Roads"
queryable="false"/>
		                        <layer name="Boundaries"
queryable="false"/>
		                        <param name="map"
value="c:/wms/basemapNew.map"/>
		                        <param name="format"
value="image/png"/>
		                        <param name="TRANSPARENT"
value="TRUE"/>
		                <param name="STYLES" value=""/>
		        </map-source>
		As far as I can tell, that's the correct format, but if
anyone sees anything out of place, or wants to try that WMS service,
please feel free to do so.  As I mentioned, I have full control over
that WMS service as well, so I can make adjustments there, too.
		Sent: Tuesday, November 29, 2011 1:32 PM
		To: TC Haddad; geomoose-users at lists.osgeo.org
		Odd, any "param"s tags should get applied.
		having:
		<param name="FORMAT">image/png</param>
		Should force the image to print as image/png, keeping
the alpha channel.
			To: "geomoose-users at lists.osgeo.org"
<geomoose-users at lists.osgeo.org>
			Sent: Wednesday, November 23, 2011 4:45 PM
layers
			Yeah the point is that if you don't specify:
			format=image/png
			in the WMS URL, then the print script will form
a url for you that includes the default value:
			format-image/jpeg
			and this is bad for your print job because JPEG
doesn't support transparency.
			The server is just delivering what the URL is
asking it to...
			Tanya
			On Wed, Nov 23, 2011 at 2:41 PM, Bob Basques
<Bob.Basques at ci.stpaul.mn.us> wrote:
			JPEG may be a catch all since Aerial photos look
best as JPEG.
			As far as the FORMAT= piece, I know that our WMS
serves in 7 different response formats.  Two different PNG formats.
			bobb
			>>> TC Haddad <tchaddad at gmail.com> wrote:
Bob,
does the actual WMS url have the "Format=" specified? even though you
have set it to respond in PNG?
because if not, it looks like the print_util.php will force it to
default to JPEG (line 112-ish)
On Wed, Nov 23, 2011 at 2:25 PM, Jim Klassen <klassen.js at gmail.com>
wrote:
	MapServer uses AGG by default in 6.x and as an option in 5.x.
	The print.php script in GeoMoose uses GD (via PHP bindings) and
is independent of MapServer. (Recall not all layers in a GeoMoose site
have to come from MapServer.)
	On Nov 23, 2011, at 16:20, TC Haddad <tchaddad at gmail.com> wrote:
		dumb question:
		Is GD really being used? I thought it was replaced (in
Mapserver) in favor of AGG a while back...
		Tanya
		On Wed, Nov 23, 2011 at 1:58 PM, Jim Klassen
<klassen.js at gmail.com> wrote:
			Why is because it isn't the proper resolution or
aspect ratio for printing.
			Why it renders different is because in GeoMoose
the browser does the image compositing. In the print utility there is no
browser so the GD library needs to handle it. Why not print from the
browser? Because not all browsers print the same and mans don't handle
printing the composited images correctly. In any case high res prints
(think plotter) would be out of the question.
			On Nov 23, 2011, at 14:27, "Bistrais, Bob"
<Bob.Bistrais at maine.gov> wrote:
				I copied over the new function and
function call in print_util.php. I get what's going on there- it's
"cutting out" the black portions of the image, but I'm still getting
these in the printable image.
				One thing I don't understand (and the
answer is probably not so simple)- the map is looking exactly as I'd
like in the application- why aren't we grabbing that image and coping it
to the output map file?
[mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Brent
Fraser
				Sent: Wednesday, November 23, 2011 11:33
AM
				To: Bistrais, Bob
				Cc: geomoose-users at lists.osgeo.org
wms layers
				Bob,
				I did a fix some time ago
(http://geomoose.org/trac/ticket/108) regarding using the alpha channel
in Print_util.php. This fix is in GeoMoose v2.4 so I'm confused...
				Best Regards,
				Brent Fraser
				On 11/23/2011 9:27 AM, Bistrais, Bob
wrote:
				It sure looks like a problem with the
alpha channels. Doesn't seem to matter which browser I use, either.
[mailto:klassen.js at gmail.com]
				Sent: Wednesday, November 23, 2011 10:43
AM
				To: Bistrais, Bob
				Cc: Bob Basques;
<geomoose-users at lists.osgeo.org <mailto:geomoose-users at lists.osgeo.org>
wms layers
				If the quality is different between PNG
and GIF you are probably using PNG24 (as PNG8 and GIF should be
identical image wise).
				My guess is a GD bug dealing with PNG24.
I'm not sure what your options are, but it sounds like the print.php
needs to be rewritten with a more modern library.
				On Nov 23, 2011, at 9:11, "Bistrais,
Bob" <Bob.Bistrais at maine.gov> wrote:
				Looks like I'm using png.
				One thing I tried was to use gif in the
mapbook.xml, for those WMS layers, but while they displayed alright, the
quality was awful.
[mailto:Bob.Basques at ci.stpaul.mn.us]
				Sent: Wednesday, November 23, 2011 10:05
AM
				To: geomoose-users at lists.osgeo.org;
Bistrais, Bob
wms layers
				What version of PNG, PNG8 PNG24, etc.
				bobb
				>>> "Bistrais, Bob"
Yes, the WMS is outputting PNG. What would be recommended instead?
From: Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
Sent: Tuesday, November 22, 2011 4:54 PM
To: geomoose-users at lists.osgeo.org; Bistrais, Bob
Something to look at . . .
What is the format of the images from the WMS service?
PNG24 vs other PNG formats have caused problem in cross browser
situations. Some versions of IE don't like one or the other for example.
bobb
>>> "Bistrais, Bob" <Bob.Bistrais at maine.gov> wrote:
I had brought up this question before but it seems to be happening
again. I have a few layers that I consume in GeoMoose by WMS. Some of
these are vecot line layers such as roads. They work perfectly in
GeoMoose map view. But when I compose a printable map, these layers have
a black background which obscures other layers and just plain looks
ugly. If I set the "transparent" property to false, the black background
goes away, but then I can't see any underlying data.
By the way, I do have control over the WMS services in this case. I
tried to set Offsite to 0 0 0, but that didn't seem to help either. The
WMS is at MapServer 6.0.1. Any suggestions?
				Geomoose-users mailing list
				Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
<mailto:Geomoose-users at lists.osgeo.org>
<http://lists.osgeo.org/mailman/listinfo/geomoose-users>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111129/7f859f61/attachment-0001.html
More information about the Geomoose-users mailing list
