[Geomoose-users] Identify- order of results
Bistrais, Bob Bob.Bistrais at maine.gov
Wed Nov 30 15:04:34 EST 2011
Hi Eli,
That makes sense and I would think that would have worked for me, but it didn't  Also tried changing layer names so they would be alphabetically difference, but still no go.
Even looking at the params in FireBug, I see the layer that I want to list first, appears first in the layers list, yet still appears second in the Identify results.  I can't figure out what is causing this switch in the order of layers.
-----Original Message-----
Sent: Wednesday, November 30, 2011 12:01 PM
To: Bistrais, Bob
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Identify- order of results
Bob,
Changing the order of the <map-source> in the mapbook.xml changes the
order for me.
HTH, Eli
On Wed, Nov 30, 2011 at 7:40 AM, Bob Bistrais <Bob.Bistrais at maine.gov> wrote:
> When the Identify tool is used, I want to control the order of layers when
> the results are presented in the right side window.  Basically, I want to
> present the coordinates, then layer "a", then layer "b".  In fact, when I
> look in FireBug, the Response and XML results show exactly what I want to
> see.  But the actual results in the window show layer "b" before "a".  I've
> also dumped the results to a text file, again, it looks like what I want,
> but not what I get in the result window.  Why is this, and is there anything
> I can do to change it?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
