[Geomoose-users] Problem with Printing - I don't get an image
Ed Boesenberg, III eboesenberg at niraengineers.com
Thu Sep 8 14:29:59 EDT 2011
Dan,
I am not exactly sure what you mean by "reference itself" but I am able to
substitute the name of the computer for "localhost" and Geomoose runs
correctly?  When I comment out that line, the resulting error message is
"Warning: imagecopymerge() expects parameter 2 to be resource, boolean given
in D:\ms4w\apps\ftmagisapp_v2\htdocs\php\print_util.php on line 238".  The
error had something to do with the location of scalebar.map file, which I
corrected.
Now when I run the print function I don't get any error messages, I get the
resulting three links to images but they are all still white, except for the
PDF which has the black border and Geomoose header image..
Sent: Thursday, September 08, 2011 10:00 AM
To: Ed Boesenberg, III; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Problem with Printing - I don't get an image
Can your server reference itself? Double check that settings.ini has a URL
that can reference.  Also in print.php there is a line that features
"E_ERROR" comment that line out and you may get more useful feedback from
PHP.
  _____
From: "Ed Boesenberg, III" <eboesenberg at niraengineers.com>
To: 'Dan Little' <danlittle at yahoo.com>; geomoose-users at lists.sourceforge.net
Sent: Thursday, September 8, 2011 8:25 AM
Subject: RE: [Geomoose-users] Problem with Printing - I don't get an image
I tried printing a single layer and I still get a blank white screen.
Sent: Thursday, September 08, 2011 9:21 AM
Funny, because I'm using PNG while doing some improvements to the printing
right now.
I would suspect that you have a "blank" layer of some sort that is whiting
out other layers.  Can you try getting it to print with just a single layer
instead of a number of them?
  _____
To: geomoose-users at lists.sourceforge.net
Sent: Thursday, September 8, 2011 7:35 AM
Subject: [Geomoose-users] Problem with Printing - I don't get an image
I am trying to setup the printing function but when I go to print and click
any of the three options, I get a blank (white) screen.  Is there an easy
fix?
I had IMAGETYPE set to agg/png which produces a very nice picture on the
screen but after searching the email archives I found a post about not being
able to print using that setting so I changed it back to GIF and I am still
getting the blank white screen.
Thanks,
Ed Boesenberg, III
Doing More with Less: The Next Generation Virtual Desktop
What are the key obstacles that have prevented many mid-market businesses
from deploying virtual desktops?  How do next-generation virtual desktops
provide companies an easier-to-deploy, easier-to-manage and more affordable
virtual desktop model.http://www.accelacomm.com/jaw/sfnl/114/51426474/
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110908/08a04bba/attachment.html
More information about the Geomoose-users mailing list
