[Geomoose-users] Selected points not drawing
    Bistrais, Bob
    Bob.Bistrais at maine.gov
    Fri Sep  9 11:29:23 EDT 2011
I have a point layer which I am querying on, through the
query_custom.php.  When I perform a query, I get results, the map zooms
to the proper extent, but the points don't highlight.  In Firebug, I can
see that the response does indeed issue a highlight.draw(POINT...) for
each result.
Also, for testing, I created a polygon layer by buffering my points, and
that will highlight if I use it.  So in other words, point data are not
highlighting although the query is working.  What else should I check?
Bob
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110909/308f1794/attachment.html
More information about the Geomoose-users
