[Geomoose-users] Installing Geomoose; What next?
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Aug 1 02:45:23 PDT 2012
Well, the IIS logs have nothing in them - they're just showing 200's (so
the page is fine from that perspective). My Logs question was more relating
to GeoMoose itself keeping logs.
If I navigate to the getmapbook.php page itself: (
http://localhost/GeoMoose/php/getmapbook.php ) - this seems to be returning
an error:
XML parsing failed
XML parsing failed: syntax error (Line: 470, Character: 10)
Reparse document as HTML
Error:
unexpected text (non-whitespace text outside root element)
Specification:
http://www.w3.org/TR/REC-xml/
467:
468: <tool name="my_tool" title="My service" type="service"
selectable="false" service="newservice" show-label="true"
icon-class="my_tool_icon"/>
469: </toolbar>
470: </mapbook>
471: PHP Warning: PHP Startup: Unable to load dynamic library
'/ms4w/Apache/php/ext/php_curl.dll' - The specified module could not be
found.
472: in Unknown on line 0
473: PHP Warning: PHP Startup: Unable to load dynamic library
'/ms4w/Apache/php/ext/php_gd2.dll' - The specified module could not be
found.
474: in Unknown on line 0
475: PHP Warning: PHP Startup: Unable to load dynamic library
'/ms4w/Apache/php/ext/php_mapscript.dll' - The specified module could not
be found.
476: in Unknown on line 0
477: PHP Warning: PHP Startup: Unable to load dynamic library
'/ms4w/Apache/php/ext/php_ogr.dll' - The specified module could not be
found.
478: in Unknown on line 0
I've confirmed those files do exist, they're in
C:\inetpub\wwwroot\ms4w\Apache\php\ext\
Geomoose is in: C:\inetpub\wwwroot\ms4w\apps\geomoose2\
All the ms4w stuff is in: C:\inetpub\wwwroot\ms4w\
Except MapServer and a couple of directories which I've moved (per the
instructions) to: c:\mapserver\
I think I've followed the instructions (they're disparate and scattered
across numerous pages, so its a bit hard to be sure), so maybe I missed
this bit, or it wasn't in them.
Looking in php.ini, it states:
*extension_dir = "/ms4w/Apache/php/ext/"*
So I manually changed it to:
*extension_dir = "/inetpub/wwwroot/ms4w/Apache/php/ext/"*
It can now load the extensions (php.ini was in the C:\mapserver, per the
instructions, whereas the extensions weren't).
The result is that GeoMoose now works.
So lessons here:
(a) It would be nice if GeoMoose had some sort of logs of its own. I can't
seem to find any indication of any existing in any of the directories.
(b) GeoMoose should probably output PHP errors directly rather than hide
them behind a generic message. This would make troubleshooting a lot easier.
(c) Documentation for IIS7 installation would be extremely helpful.
Thanks for the help folks, I'm sure I'll have more questions soon.
Jonathan
On 31 July 2012 15:09, Jim Klassen <klassen.js at gmail.com> wrote:
> I have no experience with GeoMoose on IIS but...
> You said you were getting an error saying GeoMoose could not load the
> mapbook. This means either the server returned an error (404,500, etc) or
> otherwise didn't return a valid mapbook when GeoMoose requested
> ./php/getmapbook.php.
> It would really help if you had something akin to Firebug so you could see
> what the server is sending on the getmapbook.php call. My guess is if you
> haven't moved anything from the base ms4w install is that you don't have
> PHP configured properly and IIS is sending the PHP file rather than
> executing the PHP file and sending the results.
> There are logs/error messages, but I have no idea where for IIS. With
> apache look for error.log and access.log to see what the server is up to.
> And as I said above, something like Firebug (console and network tabs are
> most useful) lets you see what GeoMoose is up to.
> Also, the local settings you are looking at would not change if the
> mapbook would get successfully loaded or not. mapserver_url could effect
> if any local maps show up or not after the mapbook in loaded.
> On Jul 31, 2012, at 5:12 AM, Jonathan Moules wrote:
> HI List,
> I'm still not making any headway. I've now read/glanced over all of the
> documentation here: http://www.geomoose.org/docs/index.html - but am none
> the wiser.
> Everything is still set to the defaults, though I have started playing
> with the "paths" in local_settings.ini.
> Unfortunately the documentation doesn't make it clear where these relative
> paths are relative to, so I can't be sure if they're correct or not.
> My paths:
> *[paths]
> root=/ms4w/apps/geomoose2/maps/
> mapserver_url=/GeoMoose_cgi/mapserv.exe
> temp=/ms4w/tmp/ms_tmp/*
> Documentation:
> *root – root for the map (only configured through local_settings.ini)
> temp – web accessible location of the temp files relative to the root of
> the domain (only configured through local_settings.ini)*
> While the "temp" one specifies "root of the domain", is that the web
> domain (i.e., "localhost"), in which case shouldn't it be called "temp_url"
> like the "mapserver_url" variable is? I have a virtual directory for ms_tmp
> set up, but changing this to point at that doesn't work either.
> Any thoughts? How do I debug what the actual problem is? Are there error
> logs somewhere?
> Thanks,
> Jonathan
> On 30 July 2012 13:12, Jonathan Moules <jonathanmoules at warwickshire.gov.uk
> > wrote:
>> Hi,
>> I've managed to (eventually) get GeoMoose 2.6 &
>> MapServer-4-Windows working with IIS7. But now when I try and access
>> GeoMoose I get the following:
>> "Could not load a mapbook. If you are the system administrator, you
>> should look into this, if you are not the system administrator you should
>> tell them about this. Suggestions:
>> The mapbook may not be returning XML.
>> The mapbook may be returning malformed XML.
>> PHP may not be responding."
>> PHP is running (a simple php script calling *phpinfo();* in the
>> GeoMoose directory shows that).
>> Unfortunately at this point the documentation seems to have a gap. I can
>> find massive amounts of detailed information about what to put in my
>> mapbooks, what different config settings etc do, but there seems to be a
>> lack of over-arching documentation. It doesn't tell me clearly where the
>> mapbooks are, what settings I need to tweak to point them at the mapbooks,
>> where the config settings.ini file is. Parts of this information seem to be
>> scattered around (I eventually managed to find
>> http://geomoose.org/docs/settings.html (I'd suggest this be pointed to
>> from "Next steps" here - http://www.geomoose.org/docs/install_ms4w.html )).
>> Shouldn't the it be loading the demo mapbook? What do I need to change
>> next? settings.ini is pointing to "mapbook.xml" and there is one of them in
>> the conf directory too.
>> Anyone have any thoughts?
>> Thanks,
>> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120801/f876e3ba/attachment.html>
More information about the Geomoose-users
