[Geomoose-users] WMS layer not working
Brent Fraser
bfraser at geoanalytic.com
Thu Aug 2 10:50:48 PDT 2012
Jonathan,
I wouldn't consider it a bug (but perhaps it could be documented
better). There are (at least?) four lists involved in the mapbook when
defining the map content in the mapbook:
1. Layer list in catalog
- defines "layers" shown in the Catalog tab in the rendered
GeoMoose interface in the browser
2. Src list for each Layer
- each Catalog Layer can reference one or more Map-Source Layers
(e.g."src=WPPGEOG3_WMS/WMS;map_source2/my_layer")
3. Map-Source list
- basically a list of servers returning map content
4. Map-Source Layer list
- each Map-Source must(?) have at least one "<layer name=" given,
but it could have more than one.
So to control the map data, GM needs to be able to uniquely
identify each entry in each list. I expect it assumes the "name="
entries are unique and stops looking when it finds a match.
Curiously, the Catalog Layers don't have names (only non-unique
titles), and that causes some backflips when using the GeoMoose API
requiring using the "src" portion as the id:
GeoMOOSE.turnLayerOn("Image/image:FullRes/all:Filler/all"); //use
the scr def since no name or id
Best Regards,
Brent Fraser
On 8/2/2012 11:14 AM, Jonathan Moules wrote:
> Hi Brent,
> I was sure I tested that (they originally came from different servers
> so I would have given them different names - testing from the same
> server was to make things more consistent), but apparently that's now
> fixed it.
> Given this, would this be a bug (not liking seperate layers with the
> same name)? The XML is still valid after all, so surely GM should be
> able to differentiate.
> Cheers,
> Jonathan
> On 2 August 2012 17:57, Brent Fraser <bfraser at geoanalytic.com> wrote:
>> Try using a different name (e.g. <map-source name="WPPGEOG3_OpenData" ) for
>> the second one. Likely GeoMOOSE just finds the first map-source with the
>> name given in the layer/catalog def.
>> Best Regards,
>> Brent Fraser
>> On 8/2/2012 10:37 AM, Jonathan Moules wrote:
>>> Hi List,
>>> I have a couple of WMS layers that I'm trying to access through GM
>>> 2.6. One works but the other doesn't.
>>> I've got the following setup in my mapbook.xml:
>>> <!--JM; Our test server internal WMS -->
>>> <map-source name="WPPGEOG3_WMS" type="wms">
>>> <url>http://wppgeog3/wms/wms.exe?</url>
>>> <layer name="WMS"/>
>>> <param name="FORMAT" value="image/png"/>
>>> <param name="TRANSPARENT" value="false"/>
>>> </map-source>
>>> <!--JM; Our test server external WMS -->
>>> <layer name="WMS_OS_OpenData"/>
>>> </map-source>
>>> <layer title="Geog3 Internal WMS" src="WPPGEOG3_WMS/WMS"
>>> show-legend="false" />
>>> <layer title="Geog3 External WMS"
>>> src="WPPGEOG3_WMS/WMS_OS_OpenData"
>>> The WPPGEOG3_WMS/WMS works just fine, however the WMS_OS_OpenData
>>> absolutely refuses to work. Firebug shows that no requests are even
>>> being made to the server for that layer. I also had it pointing to a
>>> different set of servers, again the regular WMS worked, but it refused
>>> to make the request to the WNS_OS_OpenData one. If I pan around,
>>> requests are sent to blank.gif, but none to the WMS.
>>> Both WMS services work fine in other applications.
>>> Any thoughts?
>>> Thanks,
>>> Jonathan
>>> This transmission is intended for the named addressee(s) only and may
>>> contain sensitive or protectively marked material up to RESTRICTED and
>>> should be handled accordingly. Unless you are the named addressee (or
>>> authorised to receive it for the addressee) you may not copy or use it, or
>>> disclose it to anyone else. If you have received this transmission in error
>>> please notify the sender immediately. All email traffic sent to or from us,
>>> including without limitation all GCSX traffic, may be subject to recording
>>> and/or monitoring in accordance with relevant legislation.
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
> This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
More information about the Geomoose-users
