[Geomoose-users] Probelms with GM in Fast CGI
    Jim Klassen
    klassen.js at gmail.com
    Mon Aug  6 14:14:08 PDT 2012
I am very confused about this....
The query and identify tools are PHP/mapscript based and separate already from if the main mapserv executable in is fast-cgi mode or not.  So either the fast-cgi mapserver isn't behaving as expected as a WMS source or something odd is going on with your configuration and PHP.
There is a print line commented out on line 180 of identify.php which shows the call from the PHP to the WMS service.  Can you uncomment that and see what the link returns?
Jim Klassen
On Aug 6, 2012, at 3:48 PM, Eli Adam wrote:
> Bob,
> I'm not entirely clear on the problem but here are some ideas.
> On Mon, Aug 6, 2012 at 12:18 PM, Bistrais, Bob <Bob.Bistrais at maine.gov> wrote:
>> We have been experiencing problems with GeoMoose 2.6 when MapServer is
>> running in Fast CGI mode.  This relates to problems I’ve reported in the
>> past, we finally figured out that it was the Fast CGI.  When we have
>> MapServer in Fast CGI mode, my queries and Identify operations have failed,
>> timed out, and did not return results.  We can set MapServer to run in the
> You may be able to configure query and identify for normal mode.  This
> would be as you expect in local_settings.ini and
> mapserver_url=/cgi-bin/mapserv.exe
>> normal mode, but this causes significant issues with the draw times of our
>> WMS services.
> And configure your WMS to use fast cgi.  Perhaps something like,
> <map-source name="name" type="wms" queryable="false">
>      <url>http://domain.com/fcgi-bin/mapserv?</url>
> </map-source>
> The       <url>http://domain.com/fcgi-bin/mapserv?</url> part would
> then be used to access the wms by fcgi if you have configured it that
> way.
> This page, http://mapserver.org/ogc/wms_server.html has some info on
> redirecting certainly addresses to different handling.
> There is also general MapServer docs on fcgi,
> http://www.mapserver.org/optimization/fastcgi.html
> I've not tried this myself nor do I entirely understand your problem.
> But I think that you should be able to make your wms requests use fcgi
> and all other requests to use normal mode by configuring Apache to
> handle different address patterns differently.
> HTH, Eli
>> It’s important that we resolve this problem as soon as possible.  Is there a
>> solution or workaround to this issue?
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
