[Geomoose-users] Catalog->group - can't get GM to start with group folder closed
Jim Klassen
klassen.js at gmail.com
Mon Aug 13 13:10:46 PDT 2012
If the mapbook doesn't change, and it is the stock code base, GeoMoose doesn't have anything to display the catalog differently just because the base path changed so...
* something is different in the "copy" GeoMoose
* something is different in the mapbook being sent to the browser (and this was tested false)
* the browser isn't receiving/rendering the files you (think you) have on the server.
On Aug 13, 2012, at 2:24 PM, Bistrais, Bob wrote:
> Right, I created a new httpd file for it.
> No, I didn’t change local_settings.ini in this example, although that would be done for a “real” application. But, I don’t think that should affect the group folders opening and closing either way.
> From: Jim Klassen [mailto:klassen.js at gmail.com]
> Sent: Monday, August 13, 2012 3:11 PM
> To: Bistrais, Bob
> Cc: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] Catalog->group - can't get GM to start with group folder closed
> What else did you do besides copying the directory (\ms4w\apps\geomoose2) under a new name (\ms44\apps\geomoose3)? I just tried copying the directory and it is not enough for MS4W to pickup the new name — it doesn't find it at all.
> If I also copy and modify \ms4w\httpd.d\httpd_geomoose2_ms4w.conf to \ms4w\httpd.d\httpd_geomoose3_ms4w.conf and replace all occurrences within of geomoose2 with geomoose3, the demo works as expected.
> Presumably, \ms4w\apps\geomoose3\local_settings.ini should also be modified as well to use the copied version of the mapfiles, etc.
> On Aug 13, 2012, at 1:24 PM, Bistrais, Bob wrote:
> Just to be sure, I’ve just downloaded the latest GM 2.6 download. I unzipped the demo app and it works normally. Then I made a copy of it under a new name. When I open this application, all folders are expanded. They are both residing in the same ms4w/apps directory, the only difference is the application folder name. Any ideas?
> Sent: Monday, August 13, 2012 1:16 PM
> To: Bistrais, Bob
> Resend: Message got too big for the list.
> There is something wrong with your GeoMoose install (as opposed to your mapbook). I also checked and your getmapbook.php is returning the mapbook you sent in the email. Are you sure you are using the released and/or latest version?
> I put your catalog into my app and it shows up like this to start.
> <image001.png>
> And the "nested" same groups show up when you click on them...
> <image002.png>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120813/6d412828/attachment-0001.html>
More information about the Geomoose-users
