[Geomoose-users] Catalog->group - can't get GM to start with group folder closed
Dan Little
danlittle at yahoo.com
Tue Aug 14 12:39:56 PDT 2012
I was looking at Bob's site. Bob, what did you do to the Catalog control? By default, there is not a native "nesting radio buttons" feature? And your build/dojo.js doesn't match SVN, trunk, or The GM 2.6 download.
Are you running nightly and not the standard 2.6?
>________________________________
> From: Eli Adam <eadam at co.lincoln.or.us>
>To: Ed Boesenberg <boesiii at yahoo.com>
>Cc: geomoose-users at lists.osgeo.org
>Sent: Tuesday, August 14, 2012 1:55 PM
>Subject: Re: [Geomoose-users] Catalog->group - can't get GM to start with group folder closed
>On Tue, Aug 14, 2012 at 11:34 AM, Ed Boesenberg <boesiii at yahoo.com> wrote:
>> In my GM 2.0 and GM 2.4 application I am able to click the folder icon to
>> collapse/expand the folder group but clicking the folder icon in the GM 2.6
>> demo website has no effect. You have to click the words to expand/collapse
>> the folder group. Is this by design or should a bug ticket be prepared?
>It is probably worth filing a ticket. Whether by design or not just
>impacts whether it is a defect or enhancement.
>Eli
>> -----Original Message-----
>> From: Eli Adam [mailto:eadam at co.lincoln.or.us]
>> Sent: Tuesday, August 14, 2012 2:16 PM
>> To: Ed Boesenberg
>> Cc: Bistrais, Bob; geomoose-users at lists.osgeo.org
>> group folder closed
>> On Tue, Aug 14, 2012 at 10:57 AM, Ed Boesenberg <boesiii at yahoo.com> wrote:
>>> I just visited your test website and noticed clicking the folder icon
>>> has no effect. It did not collapse.
>> If you are talking about this website,
>> http://mapservertest.maine.gov/basemap/index.html# the folder
>> expansion/collapse works for me except that you must click the words of the
>> group, not the folder.
>> Eli
>>> From: Bistrais, Bob [mailto:Bob.Bistrais at maine.gov]
>>> Sent: Tuesday, August 14, 2012 12:25 PM
>>> To: Ed Boesenberg
>>> Subject: RE: [Geomoose-users] Catalog->group - can't get GM to start
>>> Yes, tried that, but the application still starts with folders open.
>>> From: Ed Boesenberg [mailto:boesiii at yahoo.com]
>>> Sent: Tuesday, August 14, 2012 10:31 AM
>>> To: 'Jim Klassen'; Bistrais, Bob
>>> Bob,
>>> Have you tried to test it with only one small group of layers?
>>> Ed
>>> From: geomoose-users-bounces at lists.osgeo.org
>>> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Jim
>>> Klassen
>>> Sent: Tuesday, August 14, 2012 9:58 AM
>>> To: Bistrais, Bob
>>> Cc: geomoose-users at lists.osgeo.org List
>>> renderGroup in GeoMOOSE.Tab.Catalog
>>> But again... the same code (JavaScript, HTML, CSS) and the same
>>> mapbook in the same browser has to have the same results. Unless you
>>> can come up with some meaningful difference between the original path
>>> that works and the supposedly identical copy that doesn't, I am at a
>>> complete loss as to how to help. I'm starting to think your computer is
>> just messing with you.
>>> Do you have any odd things going on in the web server where it is
>>> trying to add/change content on the fly? I have see this in one case
>>> where they were using something server side to wrap all the pages with
>>> a common header that was breaking GeoMoose.
>>> On Aug 13, 2012, at 3:22 PM, Bistrais, Bob wrote:
>>> Well, I did the copy of GM, so I would guess that the file here were
>>> identical to the demo. So are we hitting different files than
>>> expected? If I do anything else to manipulate that mapbook.xml (such
>>> as change a title or something else minor), I see that change. But,
>>> we're only talking about mapbook.xml.
>>> So, going on that, then we could infer that mapbook.xml is not hitting
>>> what it should. What code is triggered by the <group> tag?
>>> From: Jim Klassen [mailto:klassen.js at gmail.com]
>>> Sent: Monday, August 13, 2012 4:11 PM
>>> To: Bistrais, Bob
>>> If the mapbook doesn't change, and it is the stock code base, GeoMoose
>>> doesn't have anything to display the catalog differently just because
>>> the base path changed so...
>>> * something is different in the "copy" GeoMoose
>>> * something is different in the mapbook being sent to the browser (and
>>> this was tested false)
>>> * the browser isn't receiving/rendering the files you (think you) have
>>> on the server.
>>> On Aug 13, 2012, at 2:24 PM, Bistrais, Bob wrote:
>>> Right, I created a new httpd file for it.
>>> No, I didn't change local_settings.ini in this example, although that
>>> would be done for a "real" application. But, I don't think that
>>> should affect the group folders opening and closing either way.
>>> Sent: Monday, August 13, 2012 3:11 PM
>>> To: Bistrais, Bob
>>> What else did you do besides copying the directory
>>> (\ms4w\apps\geomoose2) under a new name (\ms44\apps\geomoose3)? I
>>> just tried copying the directory and it is not enough for MS4W to
>>> pickup the new name - it doesn't find it at all.
>>> If I also copy and modify \ms4w\httpd.d\httpd_geomoose2_ms4w.conf to
>>> \ms4w\httpd.d\httpd_geomoose3_ms4w.conf and replace all occurrences
>>> within of geomoose2 with geomoose3, the demo works as expected.
>>> Presumably, \ms4w\apps\geomoose3\local_settings.ini should also be
>>> modified as well to use the copied version of the mapfiles, etc.
>>> On Aug 13, 2012, at 1:24 PM, Bistrais, Bob wrote:
>>> Just to be sure, I've just downloaded the latest GM 2.6 download. I
>>> unzipped the demo app and it works normally. Then I made a copy of it
>>> under a new name. When I open this application, all folders are
>>> expanded. They are both residing in the same ms4w/apps directory, the
>>> only difference is the application folder name. Any ideas?
>>> Sent: Monday, August 13, 2012 1:16 PM
>>> To: Bistrais, Bob
>>> Resend: Message got too big for the list.
>>> There is something wrong with your GeoMoose install (as opposed to
>>> your mapbook). I also checked and your getmapbook.php is returning
>>> the mapbook you sent in the email. Are you sure you are using the
>>> released and/or latest version?
>>> I put your catalog into my app and it shows up like this to start.
>>> <image001.png>
>>> And the "nested" same groups show up when you click on them...
>>> <image002.png>
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120814/37866278/attachment.html>
More information about the Geomoose-users
