[Geomoose-users] Catalog->group - can't get GM to start with group folder closed
Dan Little
danlittle at yahoo.com
Wed Aug 15 13:39:42 PDT 2012
Bob,
Thanks for posting the solution. :-)
>________________________________
> From: "Bistrais, Bob" <Bob.Bistrais at maine.gov>
>To: "Basques, Bob (CI-StPaul)" <bob.basques at ci.stpaul.mn.us>; "eadam at co.lincoln.or.us" <eadam at co.lincoln.or.us>
>Cc: "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
>Sent: Wednesday, August 15, 2012 3:37 PM
>Subject: Re: [Geomoose-users] Catalog->group - can't get GM to start with group folder closed
>After looking over the discussion, I decided it would be good to ensure I was on the current GeoMoose 2.6 release. So I downloaded this and began transferring my data, map files, etc, over to it.
>As it turned out, this is working now and you can see it at the url:
>http://mapservertest.maine.gov/basemap/index.html#
>Although I don't know exactly what was wrong, updating to the current code base did the trick. Probably my older version was on a beta.
>Many thanks to everyone for their input.
>BB
>-----Original Message-----
>From: Basques, Bob (CI-StPaul) [mailto:bob.basques at ci.stpaul.mn.us]
>Sent: Wednesday, August 15, 2012 10:35 AM
>To: Bistrais, Bob; eadam at co.lincoln.or.us
>Cc: geomoose-users at lists.osgeo.org
>Subject: RE: [Geomoose-users] Catalog->group - can't get GM to start with group folder closed
>Bob,
>If you are talking about the ortho imagery layers in the link below. They look like they are set up as sub folders to the "None" option, and not the "Orthoimagery" folder. You have , possibly by design, an additional GROUP tag with just the expand="false" param, this may be a problem, I've never had a GROUP set up without a title . . . These items may have something to do with the problems.
>In the MapBook returned, there seem to be some errant Carraige return/linefeeds in some (all?) of the layer definitions, copy and paste problem perhaps, or funky hidden characters in the editor being used? I would fix these wrapped lines first. I know there were specific problems with broken lines in the mapbook breaking previous versions of GeoMoose.
>Bobb
>From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Bistrais, Bob
>Sent: Tuesday, August 14, 2012 1:26 PM
>To: eadam at co.lincoln.or.us
>Right, that's what I have, but the application doesn't start with the folders closed, although I have the expand parameter set to "false".
>From: Eli Adam [mailto:eadam at co.lincoln.or.us]
>Sent: Tuesday, August 14, 2012 2:16 PM
>To: Ed Boesenberg
>Cc: Bistrais, Bob; geomoose-users at lists.osgeo.org
>On Tue, Aug 14, 2012 at 10:57 AM, Ed Boesenberg <boesiii at yahoo.com> wrote:
>> I just visited your test website and noticed clicking the folder icon
>> has no effect. It did not collapse.
>If you are talking about this website,
>http://mapservertest.maine.gov/basemap/index.html# the folder expansion/collapse works for me except that you must click the words of the group, not the folder.
>Eli
>> From: Bistrais, Bob [mailto:Bob.Bistrais at maine.gov]
>> Sent: Tuesday, August 14, 2012 12:25 PM
>> To: Ed Boesenberg
>> Yes, tried that, but the application still starts with folders open.
>> From: Ed Boesenberg [mailto:boesiii at yahoo.com]
>> Sent: Tuesday, August 14, 2012 10:31 AM
>> To: 'Jim Klassen'; Bistrais, Bob
>> Bob,
>> Have you tried to test it with only one small group of layers?
>> Ed
>> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Jim
>> Klassen
>> Sent: Tuesday, August 14, 2012 9:58 AM
>> To: Bistrais, Bob
>> Cc: geomoose-users at lists.osgeo.org List
>> renderGroup in GeoMOOSE.Tab.Catalog
>> But again... the same code (JavaScript, HTML, CSS) and the same
>> mapbook in the same browser has to have the same results. Unless you
>> can come up with some meaningful difference between the original path
>> that works and the supposedly identical copy that doesn't, I am at a
>> complete loss as to how to help. I'm starting to think your computer is just messing with you.
>> Do you have any odd things going on in the web server where it is
>> trying to add/change content on the fly? I have see this in one case
>> where they were using something server side to wrap all the pages with
>> a common header that was breaking GeoMoose.
>> On Aug 13, 2012, at 3:22 PM, Bistrais, Bob wrote:
>> Well, I did the copy of GM, so I would guess that the file here were
>> identical to the demo. So are we hitting different files than
>> expected? If I do anything else to manipulate that mapbook.xml (such
>> as change a title or something else minor), I see that change. But,
>> we're only talking about mapbook.xml.
>> So, going on that, then we could infer that mapbook.xml is not hitting
>> what it should. What code is triggered by the <group> tag?
>> From: Jim Klassen [mailto:klassen.js at gmail.com]
>> Sent: Monday, August 13, 2012 4:11 PM
>> To: Bistrais, Bob
>> If the mapbook doesn't change, and it is the stock code base, GeoMoose
>> doesn't have anything to display the catalog differently just because
>> the base path changed so...
>> * something is different in the "copy" GeoMoose
>> * something is different in the mapbook being sent to the browser (and
>> this was tested false)
>> * the browser isn't receiving/rendering the files you (think you) have
>> on the server.
>> On Aug 13, 2012, at 2:24 PM, Bistrais, Bob wrote:
>> Right, I created a new httpd file for it.
>> No, I didn't change local_settings.ini in this example, although that
>> would be done for a "real" application. But, I don't think that
>> should affect the group folders opening and closing either way.
>> Sent: Monday, August 13, 2012 3:11 PM
>> To: Bistrais, Bob
>> What else did you do besides copying the directory
>> (\ms4w\apps\geomoose2) under a new name (\ms44\apps\geomoose3)? I
>> just tried copying the directory and it is not enough for MS4W to
>> pickup the new name - it doesn't find it at all.
>> If I also copy and modify \ms4w\httpd.d\httpd_geomoose2_ms4w.conf to
>> \ms4w\httpd.d\httpd_geomoose3_ms4w.conf and replace all occurrences
>> within of geomoose2 with geomoose3, the demo works as expected.
>> Presumably, \ms4w\apps\geomoose3\local_settings.ini should also be
>> modified as well to use the copied version of the mapfiles, etc.
>> On Aug 13, 2012, at 1:24 PM, Bistrais, Bob wrote:
>> Just to be sure, I've just downloaded the latest GM 2.6 download. I
>> unzipped the demo app and it works normally. Then I made a copy of it
>> under a new name. When I open this application, all folders are
>> expanded. They are both residing in the same ms4w/apps directory, the
>> only difference is the application folder name. Any ideas?
>> Sent: Monday, August 13, 2012 1:16 PM
>> To: Bistrais, Bob
>> Resend: Message got too big for the list.
>> There is something wrong with your GeoMoose install (as opposed to
>> your mapbook). I also checked and your getmapbook.php is returning
>> the mapbook you sent in the email. Are you sure you are using the
>> released and/or latest version?
>> I put your catalog into my app and it shows up like this to start.
>> <image001.png>
>> And the "nested" same groups show up when you click on them...
>> <image002.png>
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120815/1d91134b/attachment-0001.html>
More information about the Geomoose-users
