[Geomoose-users] Where does the map image go..?
Jim Klassen klassen.js at gmail.com
Thu Aug 16 15:38:49 PDT 2012
1) GeoMoose doesn't render it.
2) MapServer, in most cases, send the rendered image directly to the browser and does not use a temp file.  Temp files would be created in case of a WMS source to MapServer or possibly some storage for some of the PHP based services.
If you want to save a map render as a graphic, use firebug with the network tab enabled and save the image you want out of the list.  Alternatively the print service can print to an image.
On Aug 16, 2012, at 4:32 PM, Bistrais, Bob wrote:
> I was curious as to where a generated map image goes when GeoMoose renders it?  I thought it was /ms4w/tmp/ms_tmp by default, and I have my image paths set as such, both in the ini files and the map files for the layers.  But I’m not finding any images in that directory.  Is this something to do with OpenLayers?  So if I wanted to grab a map image as a graphic, where would I find it?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120816/64d56a5e/attachment.html>
More information about the Geomoose-users mailing list
