[Geomoose-users] Unable to view layer when zoom in to certain level
Mark Volz
MarkVolz at co.lyon.mn.us
Fri Dec 7 08:03:23 PST 2012
Hello,
I noticed that you have MAXSCALEDENOM set, which I think should have the opposite effect where you cannot see something when you zoom out. It is possible that you have an invalid spatial index. If your using shapefiles look for a .qix file. If that file is older than your shapefile then you need to either delete the qix file or regenerate it using shptree. I also noticed that you don't have a fill on your polygons so unless your zoomed into an edge you will not see anything anyways.
p.s. This might be more of a Mapserver question. Mapserver is the "engine" that builds the maps, and it has pretty good documentation at mapserver.org.
Mark Volz
GIS Specialist
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Lin, Joyce
Sent: Friday, December 07, 2012 8:54 AM
To: geomoose-users at lists.osgeo.org
Subject: [Geomoose-users] Unable to view layer when zoom in to certain level
Hello,
I hope someone can help me with this. I have a polygon layer which appears when I zoom out but disappear when I zoom in to certain level. I am new to GeoMoose. Any help is appreciated!!
The layer has original projection as "init=epsg:32040"
I am publishing to GeoMoose using Mapfile below. The Project in Mapbook.xml remained the same as default EPSG:3857
MAP
NAME 'Lease'
SIZE 800 650
STATUS ON
EXTENT 2016274.741485 176555.010138 2688771.295454 620600.467750
UNITS FEET
INCLUDE "/ms4w/apps/geomoose2/maps/geomoose_globals.map"
PROJECTION
'init=epsg:3857'
END
LEGEND
STATUS ON
LABEL
TYPE TRUETYPE
FONT vera_sans
SIZE 8
COLOR 0 0 0
END
END
LAYER
NAME Lease
DATA './Lease.shp'
STATUS ON
TYPE POLYGON
LABELITEM 'TRACT_NAME'
LABELCACHE ON
LABELMAXSCALE 20000
PROJECTION
'init=epsg:32040'
END
CLASS
NAME 'Lease'
STYLE
WIDTH 3
COLOR -1 -1 -1
OUTLINECOLOR 255 204 153
MAXSCALEDENOM 15000
END
STYLE
SIZE 1
COLOR -1 -1 -1
END
LABEL
TYPE TRUETYPE
FONT vera_sans
SIZE 8
ANTIALIAS TRUE
COLOR 0 0 0
OUTLINECOLOR 254 254 200
BUFFER 4
MINFEATURESIZE auto
PARTIALS FALSE
POSITION cc
END
END
METADATA
# drill-down identify service record.
'identify_record' 'templates/identify.html'
# query.php / "Search Lease" functionality.
'itemquery' 'templates/search_result.html'
'itemquery-filter' '/.*[qstring].*/i'
'qstring_validation_pattern' '.'
# Feature reports are stored in the conf/feature_report directory.
'feature_report' 'parcel.xml'
'select_record' 'templates/select_result.html'
'select_header' 'templates/select_header.html'
'popups' 'Lease_popup.html'
END
TOLERANCE 0
END
CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_tmp/ms_error_Lease.txt"
DEBUG 5
END ## end Map
Thank you,
Joyce Lin
Statement of Confidentiality:
This message may contain information that is privileged or confidential. If you receive this transmission in error, please notify the sender by reply e-mail and delete the message and any attachments.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121207/0e495f55/attachment-0001.html>
More information about the Geomoose-users
