[Geomoose-users] MN WMS and Web Mercator Example
Dan Little
danlittle at yahoo.com
Wed Feb 15 21:44:15 EST 2012
You might want to check out the mapfiles in GeoMOOSE's SVN trunk. We have an example of reprojection the LMIC WMS into web mercator in there.
>________________________________
> From: "Moore, Richard J" <richard.moore at mnsu.edu>
>To: "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
>Sent: Wednesday, February 15, 2012 10:03 AM
>Subject: [Geomoose-users] MN WMS and Web Mercator Example
>I’m sure this question has been answered before but I can’t find the solution in the archives.
>I have a geomoose application that is using the web Mercator example as the base (900913) and I have reprojected all my data into the web projection.
>I would like to use the MNGEO/LMIC WMS server and have the aerial photography from LMIC as another set of background data.
>My first question is have other entities in Minnesota used the LMIC WMS along with the Web Mercator Example.
>If you have, can you share your map file and mapbook example so that I can cut directly to the chase. I understand the concept but some of the parameters get fuzzy. A working example would be awesome to have and plug in to my site!!
>Thanks,
>Rick
>Rick Moore
>GIS Research Analyst
>Water Resources Center
>Minnesota State University Mankato
>189 Trafton Science Center South
>Mankato, MN 56001
>(507) 389-3267 - Work
>(507) 381-7398 - Mobile
>http://cset.mnsu.edu/wrc/
> http://mrbdc.mnsu.edu/
>_______________________________________________
>Geomoose-users mailing list
>Geomoose-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/geomoose-users
Skipped content of type multipart/related
More information about the Geomoose-users
